Will caddy TLS challenge for any domain on :443
:443, h3.xx.yy, zh.xx.yy {
the config is above
somebody say if i use ** :443 ** in the Caddyfile
If someone visits:
  • random.hacker.com
  • 123.abc.xx.yy
  • your.server.ip
As long as the request reaches your server on port 443, Caddy will attempt to issue a TLS certificate for those domains (unless a wildcard certificate already covers them, or you’ve manually disabled automatic TLS).
This can result in:
  • :no_entry: Abuse of your ACME (Let’s Encrypt) rate limits;
  • :no_entry: Caddy failing to start due to certificate issuance errors (e.g. the domain isn’t yours);
  • :no_entry: Performance impact from malicious or unwanted traffic;
is it true?
No
:443 Doesn’t this setting just accept requests from all domains?
No, it doesn’t, unless explicitly configured to do so.
Just curious where you got this information
chatgpt
Ah. No wonder everything about it is incorrect… not surprised.
Next time, try just giving our docs a read.
