dogrocker
(Kanin Peanviriyakulkit)
November 16, 2017, 3:13am
#1
Hello,
I would like to use our SSL certificate (Wildcard COMODO)
Now with auto-generated Let’s Encrypt certificate. I use like this.
*.site.com {
proxy / localhost:8000 {
except /media /static
rewrite /static {
r (.*)
to /static_cdn/{1}
tls mymail@gmail.com
max_certs 3
root /opt/src
gzip
So if I set like this, Is it work with all sub domain?
*.site.com {
rewrite /static {
r (.*)
to /static_cdn/{1}
tls /etc/ssl/site_com.crt-bundle /etc/ssl/site_com.key
root /opt/src
gzip
Because my subdomain is dynamic used by username of the application.
Thanks in advance for any help that you are able to provide.
As soon as you provide keys, the site is no longer eligible for Automatic HTTPS:
Caddy automatically enables HTTPS for all your sites, given that some reasonable criteria are met:
Certificates and keys are not provided by you
That means your site will be served (over HTTPS) on port 2015 (the default when Automatic HTTPS isn’t enabled). You’ll need to specify both the HTTP and the HTTPS endpoints for your site instead, e.g.:
https://*.example.com {
tls /path/to/example.com.cert /path/to/example.com.key
http://*.example.com {
dogrocker
November 16, 2017, 4:29am
#3
So if I don’t want user use http I need to redir right ?
redir https://{host}{uri}
Thank you.
Yep! That should take care of it nicely.
system
(system)
closed
February 14, 2018, 4:48am
#5
