I have a wildcard TLS origin certificate that I have been issued by Cloudflare. I am not using a Cloudflare proxy for cloud.my-url.com
, however I am for plex.my-url.com
. When I try and use Auto HTTPS for cloud.my-url.com
, it just pulls the loaded wildcard certificate from where I load it in using the Caddyfile under the plex.my-url.com
. Since I am not using Cloudflare proxy for that subdomain, that certificate is invalid. I do not want to disable the Cloudflare strict TLS policy. How can I force cloud.my-url.com
to use Auto-HTTPS while keeping my other subdomains using my provided certs?
If I don’t specify any TLS settings cloud.my-url.com
works fine since that uses Auto HTTPS, but plex.my-url.com
does not work since the Cloudflare proxy is looking for it’s issued origin certificate.
INF ts=1694819456.30839 msg=using provided configuration config_file=/etc/caddy/Caddyfile config_adapter=caddyfile
INF ts=1694819456.3112862 logger=admin msg=admin endpoint started address=localhost:2019 enforce_origin=false origins=["//[::1]:2019","//127.0.0.1:2019","//localhost:2019"]
INF ts=1694819456.311491 logger=tls.cache.maintenance msg=started background certificate maintenance cache=0xc000700900
WRN ts=1694819456.3119485 logger=tls msg=stapling OCSP error=no OCSP stapling for [cloudflare origin certificate *.my-url.com my-url.com]: no URL to issuing certificate
INF ts=1694819456.3119984 logger=http.auto_https msg=skipping automatic certificate management because one or more matching certificates are already loaded domain=cloud.my-url.com server_name=srv0
INF ts=1694819456.3120065 logger=http.auto_https msg=skipping automatic certificate management because one or more matching certificates are already loaded domain=plex.my-url.com server_name=srv0
INF ts=1694819456.3120098 logger=http.auto_https msg=enabling automatic HTTP->HTTPS redirects server_name=srv0
v2.7.4
Docker being managed by a Portainer stack
Caddy starts on container start
version: "3.9"
image: caddy:latest
restart: always
#ports:
#- 80:80
#- 443:443
#- 443:443/udp
network_mode: host
- /Caddyfile:/etc/caddy/Caddyfile
- ./site:/srv
- caddy_data:/data
- caddy_config:/config
caddy_data:
caddy_config:
https://cloud.my-url.com:443 {
tls my-email@gmail.com
reverse_proxy localhost:11000
https://plex.my-url.com:443 {
reverse_proxy localhost:32400
tls /data/my-url.com.pem /data/my-url.com.key
