Summary
Seeing odd issues when attempting to use Let’s Encrypt wildcard
I’m sharing these here for the developers as it might point in the directions of bugs - hope this helps.
- Trying to avoid Let’s Encrypt Rate Limits for wildcard domains.
- Attempting to use
tls { wildcard \ dns route53 }
to force use Let’s Encrypt wildcard cert.
The setup / outline
Building using the following:
docker run --rm -v $(pwd):/install -e PLUGINS=cache,expires,route53 -e VERSION=0.11.0 abiosoft/caddy:builder
Note:
- I specify the version number else I seem to get a
0.10.11
build. -
0.11.0
appears to be the latest build so I believe I’m on the latest. - Version verified with
caddy -version
Problems / Oddities noticed
1. Wildcard specified hosts not accepted
It seems odd to get the following error when adding “wildcard
” to the tls
section:
/etc/caddy/Caddyfile:172 - Error during parsing: Cannot convert domain name '*.exmample.com' to a valid wildcard: already has a wildcard label
Changing the first config section in the Caddyfile
http://*.example.com,
https://*.example.com {
cache {
status_header X-Cache-Status
proxy / 95.142.xxx.xxx {
tls support@example.com {
ask http://internal-host.example.net/?action=domain_ask
to:
cache {
dns route53
wildcard
So in order to avoid this “valid wildcard” error I remove the “wildcard
” specifier under “tls
My initial thoughts were this should work.
2. Wrong SSL certificate delivered
During other configuration changes I believe the configuration was close to the following…
http://www.example.com,
https://www.example.com {
cache {
tls hello@example.com {
dns route53
wildcard
to.example.org,
to.example.net {
proxy / spgo.io {
… when this oddity occurred.
For a request to https://test1.example.com
delivered the certificate for to.example.net
