n-rodriguez
(Nicolas Rodriguez)
1
Hi there!
I’ve switched from Nginx to Caddy using this “template” : Common Caddyfile Patterns — Caddy Documentation and so far it’s working great
Now I would like to add some logs to this config but nothing seems to work
Where should I put the log
block?
Whatever I try I have a parsing error :
Jun 26 14:53:19 cloud caddy[1998992]: Error: adapting config using caddyfile: parsing caddyfile tokens for 'handle': /etc/caddy/Caddyfile:59 - Error during parsing: parsing caddyfile tokens for 'route': /etc/caddy/Caddyfile:57 - Error during parsing: parsing caddyfile tokens for 'reverse_proxy': /etc/caddy/Caddyfile:50 - Error during parsing: unrecognized subdirective log
Thank you!
matt
(Matt Holt)
2
I think you forgot to share your config
But basically, you put the log
directive where all other directives go: directly inside a site block.
I’d recommend reading this page, it is very helpful:
n-rodriguez
(Nicolas Rodriguez)
3
right
http://example.com, https://example.com {
redir https://www.{host}{uri}
*.example.com {
dns ovh {
@www host www.example.com
handle @www {
root * /data/apps/foo/public
php_fastcgi unix//data/apps/foo/shared/sockets/php-fpm.sock
@seafile host seafile.example.com
handle @seafile {
route /onlyofficeds/* {
uri strip_prefix /onlyofficeds
reverse_proxy {
to http://localhost:8067
header_up X-Forwarded-Host {host}/onlyofficeds
reverse_proxy http://localhost:8066
matt
(Matt Holt)
4
So just put it inside your site block, e.g.:
*.example.com {
log
system
(system)
Closed
6
