2.1.1
Using a custom container image, based on the official one, but I have added the cloudflare dns module.
I am trying to get Caddy to serve a subdomain with wildcard certificates for a domain which is being manged by Cloudflare.
So far I have a working solution for serving a route for *.mydomain.com. Caddy successfully acquires a wildcard certificate from Lets Encrypt and is therefore able to do a dns challenge via Cloudflare.
Unfortunately I am not able to get a wildcard certificate for *.sub.mydomain.com though. Cloudflare tells me that my api key does not have the required permissions to list the zones.
server | 2020/08/14 18:05:28 [INFO][cache:0x27ab140] Started certificate maintenance routine
server | {"level":"info","ts":1597428328.9633636,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
server | {"level":"info","ts":1597428328.9637709,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
server | {"level":"info","ts":1597428328.9696124,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["gitlab.differentdomain.com","gitlab-registry.differentdomain.com","*.sub.mydomain.com","*.mydomain.com"]}
server | 2020/08/14 18:05:29 [INFO][cache:0x28a4900] Stopped certificate maintenance routine
server | {"level":"info","ts":1597428329.005108,"msg":"autosaved config","file":"/config/caddy/autosave.json"}
server | 2020/08/14 18:05:29 [INFO][*.sub.mydomain.com] Obtain certificate; acquiring lock...
server | 2020/08/14 18:05:29 [INFO][*.sub.mydomain.com] Obtain: Lock acquired; proceeding...
server | 2020/08/14 18:05:29 [INFO][*.sub.mydomain.com] Waiting on rate limiter...
server | 2020/08/14 18:05:29 [INFO][*.sub.mydomain.com] Done waiting
server | 2020/08/14 18:05:29 [INFO] [*.sub.mydomain.com] acme: Obtaining bundled SAN certificate given a CSR
server | {"level":"info","ts":1597428329.458439,"logger":"admin","msg":"stopped previous server"}
server | 2020/08/14 18:05:29 [INFO] [*.sub.mydomain.com] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz-v3/6536168811
server | 2020/08/14 18:05:29 [INFO] [*.sub.mydomain.com] acme: use dns-01 solver
server | 2020/08/14 18:05:29 [INFO] [*.sub.mydomain.com] acme: Preparing to solve DNS-01
server | 2020/08/14 18:05:30 [INFO] [*.sub.mydomain.com] acme: Cleaning DNS-01 challenge
server | 2020/08/14 18:05:30 [WARN] [*.sub.mydomain.com] acme: cleaning up failed: no memory of presenting a DNS record for sub.mydomain.com
server | 2020/08/14 18:05:30 [INFO] Deactivating auth: https://acme-v02.api.letsencrypt.org/acme/authz-v3/6536168811
server | 2020/08/14 18:05:30 [ERROR] error: one or more domains had a problem:
server | [*.sub.mydomain.com] [*.sub.mydomain.com] acme: error presenting token: got error status: HTTP 403: [{Code:0 Message:Actor 'com.cloudflare.api.token.88af6bb45674657gfg34534dfd345345' requires permission 'com.cloudflare.api.account.zone.read' to list zones}]
server | (challenge=dns-01 remaining=[])
server | 2020/08/14 18:05:32 [ERROR] attempt 1: [*.sub.mydomain.com] Obtain: [*.sub.mydomain.com] error: one or more domains had a problem:
This is the request I am sending to Caddy’s API (actually its nearly identical to the request I am using for *.domain.com):
curl caddyhost:2019/config/apps/http/servers/srv0/routes/ -X POST -H "Content-Type: application/json" -d '{"@id":"wildcard-sub-mydomain-com","handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","headers":{"request":{"set":{"Host":["{http.request.host}"],"X-Real-Ip":["{http.request.remote.host}"]}}},"upstreams":[{"dial":"10.0.0.10:443"}]}]}]}],"match":[{"host":["*.sub.mydomain.com"]}],"terminal":true}'
Since I am able to get a wildcard certificate for *.mydomain.com, but not for *.subdomain.com, I am wondering what I may have forgotten to configure.
This is my current configuration:
"admin": {
"listen": "0.0.0.0:2019"
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":443"
"routes": [
"@id": "wildcard-mydomain-com",
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "reverse_proxy",
"headers": {
"request": {
"set": {
"Host": [
"X-Real-Ip": [
"upstreams": [
"dial": "10.0.0.5:443"
"match": [
"host": [
"*.mydomain.com"
"terminal": true
"@id": "wildcard-sub-mydomain-com",
"handle": [
"routes": [
"handle": [
"headers": {
"request": {
"set": {
"Host": [
"X-Real-Ip": [
"upstreams": [
"dial": "10.0.0.10:443"
"match": [
"host": [
"terminal": true
"tls": {
"automation": {
"policies": [
"issuer": {
"challenges": {
"dns": {
"provider": {
"api_token": "MY_CLOUDFLARE_API_TOKEN",
"name": "cloudflare"
"module": "acme"
