Wildcard cert with remote_ip by subdomain
Hi, Im trying to have a custom remote_ip matcher for one of a subdomain in a wildcard setup. So for that specific subdomain I want to restrict access by remote ip.
*.example.com {
              dns cloudflare {env.CLOUDFLARE_TOKEN}
	@foo host foo.example.com {
                remote_ip 100.64.0.0/10  // tried this but syntax is wrong
	handle @foo {
		respond "Foo!"
	@bar host bar.example.com
	handle @bar {
		respond "Bar!"
		abort
But this seems not supported by caddy: “Error during parsing: malformed host matcher: blocks are not supported”
What’s the correct syntax to achieve this please?
Maybe there is no way to do this when using wildcard certs?
through docker latest
host is ArchLinux 6.4.3-arch1-2
You need to read the reference documentation page on matchers
To address your issue, the host matcher does not take a block. To use multiple matchers AND-ed together, you need to group them into a named matcher and list the multiple matchers inside the block. Thus you need to convert the following
To
	@foo {
Yes I missed that part of the doc, thx
