1. Output of caddy version
I am just running caddy as a test vanilla install , trying to configure the admin API options via JSON.
CentOS Linux release 7.9.2009 (Core)
/usr/bin/caddy run --environ --config /etc/caddy/config.json
"admin": {
"identity": {
"identifiers": [
"127.0.0.1"
"issuers": [{
"module": "internal",
"ca": "",
"lifetime": 0,
"sign_with_root": false
"remote": {
"listen": ":2021",
"access_control": [
"public_keys": [
"<redacted>"
I’d like to know if its possible to configure caddy to have a “wildcard” identity > identifiers (i.e. “0.0.0.0” or “*”).
I am configuring caddy for a distributed network of servers and although I can just hard code all the public IPs of each of the servers in this section of the config JSON, it doesnt feel dynamic as I would have to update this portion every time a new server is added.
Is there a better way of doing this?
