I use the API to programatically configure caddy. My case is a docker instance and caddy being used as a proxy to the containers.
The process is well suitable for caddy’s architecture:
- getting the list of containers and their attributes
- for each of them building a self-contained route (what I mean by that is that the definition of the route contains all the information about that reverse proxy endpoint)
- adding all these routes as a list/table to
apps.http.servers.myserver.routes
This is perfect except for one thing: when I have an exception to HTTPS (one of the endpoints being excluded from HTTPS), this configuration goes to apps.http.servers.myserver.automatic_https.skip
in the form of a list/table of the sites.
This heavily complicated the idea of having a set of self-contained routes which can then be added to the configuration (the routines which deal with the routes not only need to return the routes but also extra information).
This is less a question and more of a comment about the consistency of the structure of the configuration.
