2017/06/11 08:55:46 http: TLS handshake error from 14.153.125.238:51203: tls: client offered an unsupported, maximum protocol version of 301
2017/06/11 09:04:44 http2: server: error reading preface from client 1.12.158.135:37804: timeout waiting for client preface
2017/06/11 09:13:45 http: TLS handshake error from 151.255.15.161:5987: EOF
2017/06/11 09:20:20 [INFO] SIGHUP: Hanging up
2017/06/11 09:20:20 http: Server closed
2017/06/11 09:20:21 http: Server closed
Hi @polaris1119,
Looks like Caddy received a SIGHUP signal.
Almost any number of circumstances could have resulted in Caddy receiving a SIGHUP. It’s entirely dependant on the environment and method you use to run Caddy.
One common reason is if you run Caddy in a terminal window and then close the window, it will send a SIGHUP.
Matthew’s right, something in your system is sending SIGHUP. You can absorb that by running Caddy with nohup
Thank you!
