Why are requests with status 400 logged as INFO nor ERROR?
Log entry for requests with status 400 as ERROR not INFO.
If not possible, how can one specifically write to a log file an entry for a request with status 400 when the log level is set to error?
2025/10/20 09:05:46.472	e[34mINFOe[0m	http.log.access.log0	handled request	{"request": {"remote_ip": "1.2.3.4", "remote_port": "53178", "client_ip": "1.2.3.4", "proto": "HTTP/1.0", "method": "POST", "host": "influxdba.b.c.d", "uri": "/api/v2/write?org=imb&bucket=sensor%2Ddata", "headers": {"Content-Length": ["109"], "Content-Type": ["application/x-www-form-urlencoded"], "User-Agent": ["fhem"], "Accept-Encoding": ["gzip,deflate"], "Authorization": ["REDACTED"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "influxdba.b.c.d"}}, "bytes_read": 109, "user_id": "", "duration": 0.001252663, "size": 176, "status": 400, "resp_headers": {"Via": ["1.1 Caddy"], "Alt-Svc": ["h3=\":443\"; ma=2592000"], "Content-Type": ["application/json; charset=utf-8"], "X-Influxdb-Build": ["OSS"], "X-Influxdb-Version": ["v2.7.11"], "X-Platform-Error-Code": ["invalid"], "Date": ["Mon, 20 Oct 2025 09:05:46 GMT"], "Content-Length": ["176"]}, "req_body": "temp_a,building=IMB,host=1R1,wing=1,floor=1,sensor=V3OLD,inventory=tempA,room= value=3.2 1760951146000000000\n"}
Docker
Debian GNU/Linux 13
		output file /log/influxdb.log {
			mode 644
			roll_size 10MiB
		format console
		level debug
		# level error
It used to be logged as ERROR prior to last year, but a change was made after this discussion:
Thanks! Interesting discussion :).
Is there then a way to parse out those “errors” specifically? Assigning 4xx responses as WARN would be surely convenient, at least for me.
