): v2.5.1
/root/caddy run --config /etc/caddy/caddy.json
os: ubuntu18.04
the following is the contents of /etc/caddy/caddy.json
"admin": {
"disabled": true
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":1443"
"logs": {},
"routes": [
"handle": [
"handler": "forward_proxy",
"hide_ip": true,
"hide_via": true,
"auth_user": "myusername",
"auth_pass": "mypassword"
"match": [
"host": [
"cd.smt.biz.st"
"handle": [
"handler": "vars",
"root": "/var/www/html"
"terminal": true
"tls_connection_policies": [
"match": {
"sni": [
"cd.smt.biz.st"
"experimental_http3": true,
"allow_h2c": true
"tls": {
"automation": {
"policies": [
"subjects": [
"cd.smt.biz.st"
"issuer": {
"email": "xyz@12.com",
"module": "acme"
3. The problem Iâm having:
i ran command: /root/caddy run --config /etc/caddy/caddy.json
i got the error message as below.
2022/07/06 15:36:57.338 INFO using provided configuration {"config_file": "/etc/caddy/caddy.json", "config_adapter": ""}
2022/07/06 15:36:57.341 WARN admin admin endpoint disabled
run: loading initial config: loading new config: loading http app module: provision http: getting tls
app: loading tls app module: decoding module config: tls: json: unknown field "issuer"
how to fix it?
