the command caddy version returns “(devel)”, actual FreeBSD pkg version is caddy-2.4.6_2.
FreeBSD 13.0
Caddy is launched by the pkg startup script.
service caddy start
yields to this:
/usr/local/bin/caddy run --pingback 127.0.0.1:13071 --config /usr/local/etc/caddy/Caddyfile --adapter caddyfile --pidfile /var/run/caddy/caddy.pid
# domain name.
http_port 80
https_port 443
servers {
protocol {
allow_h2c
experimental_http3
boleskine.patpro.net {
handle_path /images-tftp/* {
root * /usr/tftpboot/images
file_server * browse
@blocked not remote_ip 192.168.0.0/24
respond @blocked "Nope" 403
handle /inside/ {
reverse_proxy 192.168.0.2:80
handle /munin/* {
root * /usr/local/www
handle_path /foo/* {
root * /bar
root * /usr/local/www/caddy
respond "Hello, world!"
# Set up a reverse proxy:
# Serve a PHP site through php-fpm:
# php_fastcgi localhost:9000
# Enable logging:
# Caddy's structured log format:
format json
# Or, for Common Log Format:
# format single_field common_log
The Caddy server is hosted on a FreeBSD internet gateway; the box sitting between my LAN and Internet. Server is reachable from LAN and from Internet.
From Internet, I can use Firefox and Chrome and get HTTP/3 connections.
From the LAN, I can only achieve HTTP/2 connections.
I’ve compiled a curl version supporting HTTP/3 and tested from my LAN.
http2 is OK:
$ /usr/local/opt/curl/bin/curl -svoI --http2 https://boleskine.patpro.net
* Trying 78.196.217.20:443...
* Connected to boleskine.patpro.net (78.196.217.20) port 443 (#0)
* ALPN: offers h2
* ALPN: offers http/1.1
* CAfile: /etc/ssl/cert.pem
* CApath: none
} [5 bytes data]
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
} [512 bytes data]
* TLSv1.2 (IN), TLS handshake, Server hello (2):
{ [122 bytes data]
} [1 bytes data]
{ [15 bytes data]
{ [3836 bytes data]
{ [79 bytes data]
{ [36 bytes data]
} [36 bytes data]
* SSL connection using TLSv1.3 / TLS_CHACHA20_POLY1305_SHA256
* ALPN: server accepted h2
* subject: CN=boleskine.patpro.net
* start date: Apr 9 18:11:32 2022 GMT
* expire date: Jul 8 18:11:31 2022 GMT
* subjectAltName: host "boleskine.patpro.net" matched cert's "boleskine.patpro.net"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
} [5 bytes data]
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: boleskine.patpro.net]
* h2h3 [user-agent: curl/7.83.0-DEV]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x7faf92010c00)
} [5 bytes data]
> GET / HTTP/2
> Host: boleskine.patpro.net
> accept: */*
{ [5 bytes data]
{ [130 bytes data]
} [5 bytes data]
< HTTP/2 200
< alt-svc: h3=":443"; ma=2592000,h3-29=":443"; ma=2592000
< server: Caddy
< content-length: 13
< date: Sat, 16 Apr 2022 19:55:33 GMT
{ [5 bytes data]
* Connection #0 to host boleskine.patpro.net left intact
http3 fails:
$ /usr/local/opt/curl/bin/curl -svoI --http3 https://boleskine.patpro.net
* CApath: none
* Connect socket 5 over QUIC to 78.196.217.20:443
* Sent QUIC client Initial, ALPN: h3,h3-29,h3-28,h3-27
* Connection timeout after 300000 ms
* Closing connection 0
I’ve made a huge number of tcpdump+tests to pin down the issue. Caddy gets the client request from WAN interface, that’s OK because I request a hostname registered for the public IP of the gateway.
When the request is http2, the reply seems to be sent by the WAN interface and routed to the client on the LAN: (192.168.0.2-> client, 78.196.217.20-> WAN ip of gateway, 192.168.0.1->LAN ip of gateway)
# tcpdump -ni em0 port 443
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on em0, link-type EN10MB (Ethernet), capture size 262144 bytes
22:38:00.426618 IP 192.168.0.2.53931 > 78.196.217.20.443: Flags [S], seq 1273791029, win 65535, options [mss 1460,nop,wscale 6,nop,nop,TS val 2454617454 ecr 0,sackOK,eol], length 0
22:38:00.426657 IP 78.196.217.20.443 > 192.168.0.2.53931: Flags [S.], seq 3652463662, ack 1273791030, win 65535, options [mss 1460,nop,wscale 7,sackOK,TS val 2742369152 ecr 2454617454], length 0
22:38:00.426917 IP 192.168.0.2.53931 > 78.196.217.20.443: Flags [.], ack 1, win 2058, options [nop,nop,TS val 2454617454 ecr 2742369152], length 0
22:38:00.434429 IP 192.168.0.2.53931 > 78.196.217.20.443: Flags [P.], seq 1:518, ack 1, win 2058, options [nop,nop,TS val 2454617461 ecr 2742369152], length 517
When the request is http3, the reply is sent by the LAN interface, and the client have no idea what to do with it:
# tcpdump -ni em0 proto UDP and port 443
21:56:12.279789 IP 192.168.0.2.51837 > 78.196.217.20.443: UDP, length 1200
21:56:12.280409 IP 192.168.0.1.443 > 192.168.0.2.51837: UDP, length 153
21:56:13.278765 IP 192.168.0.2.51837 > 78.196.217.20.443: UDP, length 1200
21:56:13.278968 IP 192.168.0.1.443 > 192.168.0.2.51837: UDP, length 153
21:56:15.276805 IP 192.168.0.2.51837 > 78.196.217.20.443: UDP, length 1200
21:56:15.276827 IP 192.168.0.2.51837 > 78.196.217.20.443: UDP, length 1200
21:56:15.277039 IP 192.168.0.1.443 > 192.168.0.2.51837: UDP, length 153
21:56:15.277059 IP 192.168.0.1.443 > 192.168.0.2.51837: UDP, length 153
I think this is an anomaly on Caddy’s side, it should send back the reply on the interface the request was received.
So I’ve added “bind 78.196.217.20” in the Caddyfile and behavior changed. HTTP/3 requests yield to this tcpdump output:
22:21:21.464163 IP 192.168.0.2.55013 > 78.196.217.20.443: UDP, length 1200
22:21:21.464384 IP 78.196.217.20.443 > 192.168.0.2.55013: UDP, length 141
22:21:21.465355 IP 192.168.0.2.55013 > 78.196.217.20.443: UDP, length 1200
22:21:21.466285 IP 78.196.217.20.443 > 192.168.0.2.55013: UDP, length 1252
22:21:21.466299 IP 78.196.217.20.443 > 192.168.0.2.55013: UDP, length 1252
22:21:21.466310 IP 78.196.217.20.443 > 192.168.0.2.55013: UDP, length 1252
But the result client side is still not good:
$ /usr/local/opt/curl/bin/curl -svoI --http3 https://boleskine.patpro.net/
* CApath: none
* SSL certificate problem: certificate has expired
* Failed to connect to boleskine.patpro.net port 443 after 32 ms: SSL peer certificate or SSH remote key was not OK
Connecting with a browser from the LAN (Firefox for example) is still limited to http2 but shows no certificate problem at all.
Any help appreciated! Thanks
