I’m trying to initiate a websocket connection between chrome browser client and server.
Overview of my implementation :
There are set of different up and running projects. The main project is the hub to all other projects and it handle all http requests, routes and proxy to other sub projects. These all projects use load balancers. My attempt is to create a websocket connection from chrom browser to one sub project.
caddy version : 0.9.3
websocket library : github.com/gorilla/websocket
The main project’s caddy configs :
https://{$DOMAIN_NAME}/analytics/ {
tls ../resources/security/server.pem ../resources/security/server.key
proxy / https://localhost:8107/analytics {
websocket
insecure_skip_verify
The sub project’s caddy configs :
localhost:{$ANALYTICS_CADDY_PORT}/analytics {
root webapps/analytics
gzip
ext .html
tls {$ANALYTICS_CERTIFICATE_FILE} {$ANALYTICS_KEY_FILE}
proxy /api https://localhost:{$ANALYTICS_HTTPS_PORT} {
websocket
Inside the analytics sub project, " /api/ws " would trigger CreateSocketConnection() method.
//Starting the API server
router := routes.NewRouter()
http.Handle("/", router)
http.HandleFunc("/api/ws", api.CreateSocketConnection)
CreateSocketConnection implementation :
func CreateSocketConnection(w http.ResponseWriter, r *http.Request) {
var upgrader = websocket.Upgrader{
ReadBufferSize: 1024,
WriteBufferSize: 1024,
_, err = upgrader.Upgrade(w, r, nil)
if err != nil {
log.Fatal("upgrader failed :", err.Error())
//controllers.HandleSocket(ws)
Client side implementation :
conn = new WebSocket("wss://xxxx.com/analytics/api/ws");
Issue is I’m not getting any error log in backend, but the socket connection fails on browser.
WebSocket connection to 'wss://xxxx.com/analytics/api/ws' failed: Error during WebSocket handshake: Unexpected response code: 502
Request header :
Accept-Encoding:gzip, deflate, sdch, br
Accept-Language:en-US,en;q=0.8
Cache-Control:no-cache
Connection:Upgrade
Cookie:username=admin; tenantid=1; tenantdomain=super.com;
DNT:1
Host:xxxx.com
Origin:https://xxxx.com
Pragma:no-cache
Sec-WebSocket-Extensions:permessage-deflate; client_max_window_bits
Sec-WebSocket-Key:O/DS1lRHzXptoWz5WR131A==
Sec-WebSocket-Version:13
Upgrade:websocket
User-Agent:Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/54.0.2840.59 Safari/537.36
But the response header is as follows :
Content-Encoding:gzip
Content-Length:40
Content-Type:text/plain; charset=utf-8
Date:Sat, 29 Oct 2016 03:13:23 GMT
Server:Caddy
Vary:Accept-Encoding
X-Content-Type-Options:nosniff
Please note that I’m getting the request header inside the CreateSocketConnection method as follows :
> map[
Connection:[Upgrade] X-Forwarded-For:[127.0.0.1, 127.0.0.1] Dnt:[1] Origin:[https://xxxx.com] Pragma:[no-cache] Sec-Websocket-Extensions:[permessage-deflate; client_max_window_bits] Sec-Websocket-Version:[13] Accept-Encoding:[gzip] User-Agent:[Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/54.0.2840.59 Safari/537.36] Cache-Control:[no-cache] Sec-Websocket-Key:[O/DS1lRHzXptoWz5WR131A==] Upgrade:[websocket] Cookie:[username=admin; tenantid=1; tenantdomain=super.com; ] Accept-Language:[en-US,en;q=0.8]]
Am I missing something in my implementation?
Thanks in advance
