Hello,
I am working with a websocket connection behind proxy. The websocket is used to inform the user of a completion status of a downloaded file with status bar. After 25% the websocket stops reporting back.
I looked at other posts and initially though it was a timeout issue. I have adjusted the timeout to various settings like 5m / 1hr / 2 hr / and none. It didn’t help.
I don’t see anything in the logs that indicates a problem. Can someone help me troubleshoot this further to see what is happening? It works fine on a nginx reverse proxy.
Files are large about 50mb on average.
I am currently using version: Caddy 0.10.8
app.test1.com {
timeouts 2h
proxy / localhost:3000 {
websocket
Thank you!
