1. Output of caddy version
Latest caddy2 docker image
docker
docker
whatever the docker image runs
default docker
just the default for now
WebFinger is a nice idea for binding your blog to your identity. E.g. your mastodon account. Unfortunately the webfinger specification is written so that it assumes code is responding to your GET /.well-known/webfinger?resource=$what
request. I (and many others) run our blogs as static web pages. Ideally webfinger would have been specified as /.well-known/webfinger/acct/example.com/carol
instead of /.well-known/webfinger?resource=acct:carol@example.com
Can a caddy rewrite rule be used to transform from the GET params to a file name? Or do I have to just specify a static file for /.well-known/webfinger
which then returns my info regardless of the resource/query?
none yet
googling and reading relevant documentation
