You definitely need a forward slash /
not a backslash \
, but yes, you’re right, you need a *
as your request matcher for the rewrite
, otherwise the leading /
gets taken as being the path matcher.
changed the slashes, should I mark it as the last comment as solution?
- also one last thing, now my config is
*.xamyr.com {
rewrite * /{labels.2}{uri}
reverse_proxy localhost:3000
I want it to be http not https, what are the lines to add
Just put http://
in front.
alpha.xamyr.com {
there is another issue, everything work as suggested if there is something after /
https://alpha.xamyr.com/admin ==
proxies ~ https://xamyr.com/alpha/admin
# works perfectly
but if it is just https://alpha.example.com, it automatically redirects to https://alpha.example.com/alpha
https://alpha.xamyr.com !=
redirects to ~ https://alpha.xamyr.com/alpha
# doesn't work
I’m not sure I really understand, but the redirect is probably being performed by your upstream app.
