when running caddy in docker
there is volumes tag where we have pwd for Caddyfile and site
I have a golang server I need to have in the site directory created when I run my container having the server, database and caddy images so that when I make changes to my server code without running docker-compose again it reflects.
I understand there are hot reloading options like ‘air’ but I have seen html files done the same with volumes and changes reflect like hot reload scenarios
When you post a topic in the Help category there is a template that appears. If you fill that out we will better understand what you are asking and how to help you. I’m not quite sure there’s enough info here to make sense of what you’re asking right now.
