1. Caddy version:
2.6.2
Using docker-compose
Github actions.
version: '3'
mongo:
image: mongo:latest
- "27019:27017"
- internal
squidex1:
image: squidex-local
- URLS__BASEURL=http://localhost:8080
- ASSETS__RESIZERURL=http://resizer
- EVENTSTORE__MONGODB__CONFIGURATION=mongodb://mongo
- EVENTSTORE__MONGODB__DATABASE=squidex1
- GRAPHQL__CACHEDURATION=0
- IDENTITY__ADMINCLIENTID=root
- IDENTITY__ADMINCLIENTSECRET=xeLd6jFxqbXJrfmNLlO2j1apagGGGSyZJhFnIuHp4I0=
- IDENTITY__MULTIPLEDOMAINS=true
- RULES__RULESCACHEDURATION=00:00:00
- SCRIPTING__TIMEOUTEXECUTION=00:00:10
- SCRIPTING__TIMEOUTSCRIPT=00:00:10
- STORE__MONGODB__CONFIGURATION=mongodb://mongo
- STORE__MONGODB__DATABASE=squidex1
- STORE__MONGODB__CONTENTDATABASE=squidex1_content
- STORE__TYPE=MongoDB
- TEMPLATES__LOCALURL=http://localhost:5000
- ASPNETCORE_URLS=http://+:5000
- internal
depends_on:
- mongo
squidex2:
- URLS__BASEURL=http://localhost:8081/squidex/
- URLS__BASEPATH=squidex/
- EVENTSTORE__MONGODB__DATABASE=squidex2
- STORE__MONGODB__DATABASE=squidex2
- STORE__MONGODB__CONTENTDATABASE=squidex2_content
- internal
depends_on:
- mongo
squidex3:
- URLS__BASEURL=http://localhost:8082
- CONTENTS__OPTIMIZEFORSELFHOSTING=true
- EVENTSTORE__MONGODB__DATABASE=squidex3
- STORE__MONGODB__DATABASE=squidex3
- STORE__MONGODB__CONTENTDATABASE=squidex3_content
- internal
depends_on:
- mongo
resizer:
image: squidex/resizer:dev-40
- internal
depends_on:
- mongo
webhookcatcher:
image: tarampampam/webhook-tester
command: serve --port 1026
- "1026:1026"
- internal
squidex_proxy1:
image: squidex/caddy-proxy
- "8080:8080"
- SITE_ADDRESS=http://localhost:8080
- SITE_PATH=*
- SITE_SERVER="squidex1:5000"
depends_on:
- squidex1
- internal
squidex_proxy2:
image: squidex/caddy-proxy-path
- "8081:8081"
- SITE_ADDRESS=http://localhost:8081
- SITE_PATH=/squidex/*
- SITE_SERVER="squidex2:5000"
depends_on:
- squidex2
- internal
squidex_proxy3:
- "8082:8082"
- SITE_ADDRESS=http://localhost:8082
- SITE_PATH=*
- SITE_SERVER="squidex3:5000"
depends_on:
- squidex2
- internal
internal:
driver: bridge
{$SITE_ADDRESS}
reverse_proxy {$SITE_SERVER}
{$SITE_ADDRESS}
reverse_proxy {$SITE_PATH} {$SITE_SERVER}
I am running a few tests for my headless CMS in github actions. I use several setups:
- Site is hosted under root path (caddyfile 1)
- Site is hosted under sub path (caddyfile 2)
- Another db setting (does not matter here)
In my tests I check whether some headers are configured correctly:
var rawClient = _.ClientManager.CreateHttpClient();
var response = await rawClient.PostAsJsonAsync($"/api/content/{_.AppName}/graphql", query);
Assert.Equal(new string[]
"Auth-State",
"X-Flatten",
"X-Languages",
"X-NoCleanup",
"X-NoEnrichment",
"X-NoResolveLanguages",
"X-Resolve-Urls",
"X-ResolveFlow",
"X-Unpublished"
}, response.Headers.Vary.Order().ToArray());
The tests works fine under the root path, but under the sub path the headers are empty. Except the path I do not see any difference in my setup. Could there be a reason why the “Vary” header is omitted by caddy?
