I’ve created a new plugin that helped satisfy our reverse proxy requirements.
I tried to generalize it so it may be useful to others.
It’s still WIP but would greatly appreciate feedback from the caddy developer community.
Thanks!
Thanks!
Interesting! Thanks for sharing this!
Just wondering, what does this help you do that the vars_regexp
matcher does not? JSON Config Structure - Caddy Documentation
Hi Matt
I wanted to be able to use another placeholder to evaluate the regex against plus I needed to optionally overwrite or skip overwriting existing placeholders with the same name when generating the results.
I added a few examples towards the end of the README
Can you see a way of achieving the same using the vars_regexp matcher?
