Vars and map not visible in the plugin?
I am trying to use a variable to build a custom key for a cache plugin - this is not yet merged by @darkweak.
While testing the PR I noticed that my variable is not seen by the plugin, although it is available to be sent as additional custom header.
I also tried to set the variable through vars with the same result.
Am I missing something? Did I misread the caddy order?
$ curl -IX GET "test.example.local/gg/dd?aa=11&rr=22"
HTTP/1.1 200 OK
Cache-Control: public
Cache-Status: Souin; fwd=uri-miss; stored; key=/gg/dd
Content-Length: 25
Content-Type: text/html; charset=utf-8
Custom-Cache-Key: /gg/dd?aa=11&rr=22
docker compose.
  proxy:
    image: caddy:souin
      - "0.0.0.0:80:80"
      - "0.0.0.0:443:443"
    - ./etc/caddy:/etc/caddy
    - ./var/config:/config
    - ./var/data:/data
    - ./var/logs:/logs
    working_dir: /etc/caddy
	order cache before rewrite
		output file /logs/main.log
		format json {
			time_format iso8601
	local_certs
	cache {
		default_cache_control public
	header Content-Type "text/html; charset=utf-8"
	respond "Nothing here... Yet??????"
http://test.example.local {
	map {http.request.uri.query} {cacheKey} {
		~^(.*)(?:[?&]some_id=[^&]*)$ "?${1}"
		~^(some_id=[^&]*&?)(.*)$ "?${2}"
		~^([^&]*)(&some_id=[^&]*)(&?.*)$ "?${1}${3}"
		~^(.+)$ "?${1}"
	header Custom-Cache-Key {http.request.uri.path}{cacheKey}
	cache {
		key {
			template {http.request.uri.path}{cacheKey}
This was resolved by @darkweak in the PR mentioned above.
