I have a public server that is in alpha production. Caddy1 has been working great there for a while. So I’m upgrading to Caddy2 RC1 but it is failing with errors.
With Caddy1 it was running and storing certificates in /etc/ssl/caddy. Those certs are still there. But as I understand it now stores them in $HOME (/var/lib/caddy).
I installed Caddy2 almost verbatim per this: Install — Caddy Documentation
Can anyone offer any suggestions?
1. My Caddy version (caddy version
$ which caddy
/usr/bin/caddy
$ caddy version
v2.0.0-rc.1 h1:DxUlg4kMisXwXVnWND7KEPl1f+vjFpIOzYpKpfmwyj8=
A vps at Upcloud.com running Ubuntu 18.04.
$ uname -a
Linux 4.15.0-91-generic #92-Ubuntu SMP Fri Feb 28 11:09:48 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
$ systemd --version
systemd 237
+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid
sudo systemctl daemon-reload
sudo systemctl enable caddy
sudo systemctl start caddy
Uses caddy.service file:
Description=Caddy Web Server
After=network.target
Restart=on-failure
ExecStart=/usr/bin/caddy run --config /etc/caddy/Caddyfile --resume --environ
#ProtectHome=true // TODO try enabling this
Almost verbatim from : dist/caddy.service at master · caddyserver/dist · GitHub
https://redacted.com {
handle /api/* {
# TODO add health checks
reverse_proxy localhost:8223
root * /var/www/redacted.com
try_files {path} /index.html
Fails with errors, see below.
Apr 03 14:52:29 systemd[1]: Started Caddy Web Server.
Apr 03 14:52:29 caddy[4975]: caddy.HomeDir=/var/lib/caddy
Apr 03 14:52:29 caddy[4975]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Apr 03 14:52:29 caddy[4975]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Apr 03 14:52:29 caddy[4975]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Apr 03 14:52:29 caddy[4975]: runtime.GOOS=linux
Apr 03 14:52:29 caddy[4975]: runtime.GOARCH=amd64
Apr 03 14:52:29 caddy[4975]: runtime.Compiler=gc
Apr 03 14:52:29 caddy[4975]: runtime.NumCPU=1
Apr 03 14:52:29 caddy[4975]: runtime.GOMAXPROCS=1
Apr 03 14:52:29 caddy[4975]: runtime.Version=go1.14.1
Apr 03 14:52:29 caddy[4975]: os.Getwd=/
Apr 03 14:52:29 caddy[4975]: LANG=C
Apr 03 14:52:29 caddy[4975]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Apr 03 14:52:29 caddy[4975]: HOME=/var/lib/caddy
Apr 03 14:52:29 caddy[4975]: LOGNAME=caddy
Apr 03 14:52:29 caddy[4975]: USER=caddy
Apr 03 14:52:29 caddy[4975]: INVOCATION_ID=1a7d71df05f74ed5a22db3e4604537d9
Apr 03 14:52:29 caddy[4975]: JOURNAL_STREAM=9:543069
Apr 03 14:52:29 caddy[4975]: {"level":"info","ts":1585925549.1357584,"msg":"resuming from last configuration","autosave_file":"/var/lib/caddy/.config/caddy/autosave.json"}
Apr 03 14:52:29 caddy[4975]: {"level":"info","ts":1585925549.136814,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["localhost:2019"]}
Apr 03 14:52:29 caddy[4975]: {"level":"info","ts":1585925549.1373339,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
Apr 03 14:52:29 caddy[4975]: {"level":"info","ts":1585925549.1374652,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Apr 03 14:52:29 caddy[4975]: {"level":"info","ts":1585925549.1375701,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Apr 03 14:52:29 caddy[4975]: 2020/04/03 14:52:29 [INFO][cache:0xc000445450] Started certificate maintenance routine
Apr 03 14:52:29 caddy[4975]: {"level":"info","ts":1585925549.1388898,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["redacted.com"]}
Apr 03 14:52:29 caddy[4975]: {"level":"info","ts":1585925549.1391227,"logger":"tls","msg":"cleaned up storage units"}
Apr 03 14:52:29 caddy[4975]: {"level":"info","ts":1585925549.1393428,"msg":"autosaved config","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Apr 03 14:52:29 caddy[4975]: {"level":"info","ts":1585925549.1394496,"msg":"serving initial configuration"}
Apr 03 14:52:29 caddy[4975]: 2020/04/03 14:52:29 [INFO][redacted.com] Obtain certificate; acquiring lock...
Apr 03 14:52:29 caddy[4975]: 2020/04/03 14:52:29 [INFO][redacted.com] Obtain: Lock acquired; proceeding...
Apr 03 14:52:29 caddy[4975]: 2020/04/03 14:52:29 [INFO][redacted.com] Waiting on rate limiter...
Apr 03 14:52:29 caddy[4975]: 2020/04/03 14:52:29 [INFO][redacted.com] Done waiting
Apr 03 14:52:29 caddy[4975]: 2020/04/03 14:52:29 [INFO] [redacted.com] acme: Obtaining bundled SAN certificate given a CSR
Apr 03 14:52:29 caddy[4975]: 2020/04/03 14:52:29 [INFO] [redacted.com] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz-v3/3738029760
Apr 03 14:52:29 caddy[4975]: 2020/04/03 14:52:29 [INFO] [redacted.com] acme: use tls-alpn-01 solver
Apr 03 14:52:29 caddy[4975]: 2020/04/03 14:52:29 [INFO] [redacted.com] acme: Trying to solve TLS-ALPN-01
Apr 03 14:52:30 caddy[4975]: 2020/04/03 14:52:30 [INFO] Deactivating auth: https://acme-v02.api.letsencrypt.org/acme/authz-v3/3738029760
Apr 03 14:52:30 caddy[4975]: 2020/04/03 14:52:30 [ERROR] acme: Error -> One or more domains had a problem:
Apr 03 14:52:30 caddy[4975]: [redacted.com] [redacted.com] acme: error presenting token: presenting with embedded provider: could not start listener at :443 for challenge server: listen tcp :443: bind: address already in use
Apr 03 14:52:30 caddy[4975]: (challenge=tls-alpn-01 remaining=[http-01])
Apr 03 14:52:32 caddy[4975]: 2020/04/03 14:52:32 [INFO] [redacted.com] acme: Obtaining bundled SAN certificate given a CSR
Apr 03 14:52:32 caddy[4975]: 2020/04/03 14:52:32 [INFO] [redacted.com] AuthURL: https://acme-v02.api.letsencrypt.org/acme/authz-v3/3738030334
Apr 03 14:52:32 caddy[4975]: 2020/04/03 14:52:32 [INFO] [redacted.com] acme: Could not find solver for: tls-alpn-01
Apr 03 14:52:32 caddy[4975]: 2020/04/03 14:52:32 [INFO] [redacted.com] acme: use http-01 solver
Apr 03 14:52:32 caddy[4975]: 2020/04/03 14:52:32 [INFO] [redacted.com] acme: Trying to solve HTTP-01
Apr 03 14:52:32 caddy[4975]: 2020/04/03 14:52:32 [INFO] Deactivating auth: https://acme-v02.api.letsencrypt.org/acme/authz-v3/3738030334
Apr 03 14:52:32 caddy[4975]: 2020/04/03 14:52:32 [ERROR] acme: Error -> One or more domains had a problem:
Apr 03 14:52:32 caddy[4975]: [redacted.com] [redacted.com] acme: error presenting token: presenting with embedded provider: could not start listener at :80 for challenge server: listen tcp :80: bind: address already in use
Apr 03 14:52:32 caddy[4975]: (challenge=http-01 remaining=[])
Apr 03 14:52:34 caddy[4975]: 2020/04/03 14:52:34 [ERROR] attempt 1: [redacted.com] Obtain: [redacted.com] acme: Error -> One or more domains had a problem:
Apr 03 14:52:34 caddy[4975]: [redacted.com] [redacted.com] acme: error presenting token: presenting with embedded provider: could not start listener at :80 for challenge server: listen tcp :80: bind: address already in use
Apr 03 14:52:34 caddy[4975]: - retrying in 1m0s (5.516414869s/720h0m0s elapsed)...
Apr 03 14:52:43 systemd[1]: Stopping Caddy Web Server...
Apr 03 14:52:43 caddy[4975]: {"level":"info","ts":1585925563.7457967,"msg":"shutting down apps then terminating","signal":"SIGTERM"}
Apr 03 14:52:43 caddy[4975]: 2020/04/03 14:52:43 [INFO][cache:0xc000445450] Stopped certificate maintenance routine
Apr 03 14:52:43 caddy[4975]: {"level":"info","ts":1585925563.7464712,"msg":"shutdown done","signal":"SIGTERM"}
Apr 03 14:52:43 systemd[1]: Stopped Caddy Web Server.
Problem seems to start here:
I’ve verified I have nothing using :80 or :443:
$ sudo ss -tulw | grep :80
$ sudo ss -tulw | grep :443
Firewall ports are open:
$ sudo ufw status verbose
Status: active
To Action From
80/tcp ALLOW IN Anywhere
443/tcp ALLOW IN Anywhere
80/tcp (v6) ALLOW IN Anywhere (v6)
443/tcp (v6) ALLOW IN Anywhere (v6)
