vitalyavolyn
(Vitaliy Volynskiy)
#1
v2.3.0-beta.1
caddy start
(just testing my Caddyfile before upgrading to v2)
linux
my.domain {
route /api/* {
uri strip_prefix /api
reverse_proxy :3000
import vkapps-cors
route /bot/* {
uri strip_prefix /bot
reverse_proxy :3001
import
directive doesn’t work inside route
run: adapting config using caddyfile: parsing caddyfile tokens for 'route': Caddyfile:60 - Error during parsing: unrecognized directive: import
Note
I moved my import
statement above route
, it works fine, but i figured i need to repost this bug somewhere. Is this intended?
Is vkapps-cors
a file? I don’t see a snippet defined in the Caddyfile you posted. It works fine for me if I define a snippet.
Also, you can replace route
and uri strip_prefix
with just handle_path
(vkapps-cors) {
my.domain {
handle_path /api/* {
reverse_proxy :3000
import vkapps-cors
handle_path /bot/* {
reverse_proxy :3001
# Fallback for paths not otherwise handled
vitalyavolyn
(Vitaliy Volynskiy)
#3
Thanks for the tip! handle_path
is much better and import
works inside it.
Oops, i forgot the snippet:
(vkapps-cors) {
header Access-Control-Allow-Headers origin,content-type,accept,x-vk-sign
But putting import
inside route
produced the error above.
I can’t reproduce that problem. This works fine to me:
Caddyfile:
(vkapps-cors) {
my.domain {
route /api/* {
reverse_proxy :3000
import vkapps-cors
route /bot/* {
reverse_proxy :3001
$ caddy adapt --pretty
2020/12/10 21:07:15.202 INFO using adjacent Caddyfile
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":443"
"routes": [
"match": [
"host": [
"my.domain"
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"routes": [
"handle": [
"handler": "rewrite",
"strip_path_prefix": "/api"
"handle": [
"handler": "reverse_proxy",
"upstreams": [
"dial": ":3000"
"handle": [
"handler": "headers",
"response": {
"set": {
"Access-Control-Allow-Headers": [
"origin,content-type,accept,x-vk-sign"
"match": [
"path": [
"/api/*"
"handle": [
"routes": [
"handle": [
"strip_path_prefix": "/bot"
"handle": [
"upstreams": [
"dial": ":3001"
"match": [
"path": [
"/bot/*"
"terminal": true
system
(system)
closed
#5
