Make sure you’re using beta 18 or newer.
Ah, I see. I think setting up my own docker dev environment for a locally customized caddy goes beyond my ability. I will wait patiently for the updates. Thank you for all your help.
I figured out how to do what I want via the openresty implementation of nginx, and after working with that, I can see why you were motivated to create Caddy. Here’s my solution for anyone who may come upon this thread.
I also needed to unescape the query parameters from the GET request in order to properly write them into the POST body, and if that is not already implemented in Caddy, I guess it would be easy to add. Thanks again for your support in this forum.
Yes, when Caddy placeholders access query string parameters, the returned value is already decoded.
In any case, your task will be much easier with Caddy than with nginx – probably Caddy 2.1 or something around there.
