Is there any valid way to allow a reverse proxy handler (currently manually invoked from a custom handler, though this should not matter since in the end we just return rp.ServeHTTP(..)
) to execute middleware on the response, or does ‘terminating’ in the documentation mean it terminates both ways: both request-wise and response-wise?
If so, what would be the suggested way to alter the response from reverseproxy.Handler.ServeHTTP()
, preferably without duplicating code by replicating the HTTP proxying code and doing a manual HTTP request to the backend for the URLs that we’d like to filter?
The configuration used is along the lines of the following:
caddyhttp.Route{
MatcherSetsRaw: caddyhttp.RawMatcherSets{
map[string]json.RawMessage{
"host": wrapJSON([]string{fmt.Sprintf("*.%v", domainName)}),
HandlersRaw: []json.RawMessage{
wrapJSONHandler("templates", map[string]interface{}{
"include_root": "",
"mime_types": []string{"text/html", "text/plain", "text/plain; charset=utf-8"},
wrapJSONHandler("cfx_nucleus", map[string]interface{}{}),
(wrapJSONHandler
is just a helper which adds a handler
key and merges in the interface itself)
EDIT: ah, mea culpa: this seems to work fine for a page with a response Content-Type of text/html; charset=utf-8
, but a JSON response which has a Content-Type of text/plain; charset=utf-8
does not get the value filtered, interestingly - perhaps this is due to JSON’s usage of {}
