caddy:latest@sha256:90a12b5c957bab94f57aadfd9e655d414ab69443495f22ef430152181ab0aede
the docker image i am using
Docker
Docker
Same as b
www.example.com, example.com {
tls /opt/caddy/certs/cert.pem /opt/caddy/certs/key.pem
respond "Hello there! sorry the site has been down so long, the motherboard died so i had to get a new server mobo"
None, just got my server back up, redoing everything, and i was curious if it’s possible to have the tls
directive globally set so I don’t have to add it to every single site config
Not Related
No clue what to try, asking here
None that I know of, will update if any are given/found
Misc
Basically, I want to be able to have the config file that caddy is pointed at, contain this and only this
tls /opt/caddy/cert.pem /opt/caddy/key.pem
import /opt/caddy/sites/*.conf
and then have the site configs in /opt/caddy/sites/hostname.conf
if i have to change run time variables, like a flag, or a env, i have no problem doing so, i am using cloudflare-strict-tls, so this is why i want it like this
