Latest docker build (but with cloudflare plugin)
Docker on unRAID v6.8.2
docker run -d --name='caddy' --net='bridge' -e 'CLOUDFLARE_AUTH_TOKEN'='#########' -p '80:80/tcp' -p '443:443/tcp' -v '/mnt/user/appdata/caddy/Caddyfile:/etc/Caddyfile' -v '/mnt/user/appdata/caddy':'/root/.caddy':'rw' 'abiosoft/caddy'
https://hub.docker.com/r/abiosoft/caddy/dockerfile
stream.lightsong.cc:443 {
reverse_proxy 192.168.1.20:32400 {
tls amman.sood@gmail.com {
dns cloudflare {env.CLOUDFLARE_AUTH_TOKEN}
client auth {
mode require_and_verify
trusted_ca_cert_file origin-pull-ca.pem
dl.lightsong.cc {
reverse_proxy 192.168.1.20:8112 {
radarr.lightsong.cc {
reverse_proxy 192.168.1.20:7878 {
share.lightsong.cc {
reverse_proxy 192.168.1.20:8686 {
sonarr.lightsong.cc {
reverse_proxy 192.168.1.20:8989 {
stats.lightsong.cc {
reverse_proxy 192.168.1.20:8181 {
3. The problem Iâm having:
Iâm trying to upgrade my ancient deprecated Caddy install to v2, but no matter what I try, it immediately exits with âunknown directiveâ. I followed the V2 upgrade guide and I think I have all the syntax right, so I have no clue why it wonât run.
2020/09/11 01:49:10 /etc/Caddyfile:2 - Error during parsing: Unknown directive âreverse_proxyâ
I tried using reverse_proxy without the { } after it, no dice. I originally had âencode gzipâ as the first line for each site definition, but that also gave me an unknown directive error.
Thanks in advance, been bashing my head into this for a few hours now, ended up going back to my V1 install for now.
