V2: Caddy php config help
Reading the code, seems like you should be able to configure pathinfo_fetch with REQUEST_URI to make it work…
But to me, it seems that thinkphp’s implementation on v5.1 seems incorrect.
Thanks, I was able to configure the configure the pathinfo_fetch was indeed the correct way to go. There are some remaining problem that I will look into.
