v2
First, I’m new In Caddy and certificats implementation
I have a registred domain “mydomain.com” and many docker services runing on my server (node, kibana, mysql, …). I used Caddy v1 to access my main domain “mydomain.com” only.
After that I migrate to Caddy v2 and he generates certificates for “www.mydomain.com” with (www) -New installation-. It works fine with the official docker image : Docker Hub
Now, I want to use Caddy v2 as a reverse-proxy to access my domain and all my sub-domains “*.mydomain.com” using the one new certificate (not using old ones)
My actual configuration is :
- docker-compose :
version: "3.5"
rproxy-auto:
image: caddy
container_name: rproxy-auto
# user: "${UID}:${GID}"
- 443:443
- 2015:2015
- 2019:2019
- 2020:2020
- ./data:/data
- ./www:/usr/share/caddy
- ./config:/config
- Caddyfile (see the confi section)
Docker installed on Debian Jessie
docker-compose up --build -d
http://mydomain.com {
redir mydomain.com{uri}
mydomain.com {
reverse_proxy 12.1.1.1:9000
service1.mydomain.com {
reverse_proxy 12.1.1.1:9001
service2.mydomain.com {
reverse_proxy 12.1.1.1:9002
If we refer to the documentation we have many ways to configure Caddy v2. But I don’t find this details in documentation :
- Where we must put configuration files (Caddyfile or .json) on docker
- When Caddy v2 load the configuration file (startup of the docker, after each edit, after Caddy reload) ?
Dosen’t work :
Thanks a lot for your help
