FreeNAS 11.3-U4.1
service caddy start
#!/bin/sh
# $FreeBSD$
# PROVIDE: caddy
# REQUIRE: LOGIN DAEMON NETWORKING
# KEYWORD: shutdown
# Add the following lines to /etc/rc.conf.local or /etc/rc.conf
# to enable this service:
# caddy_enable (bool): Set to NO by default. Set it to YES to enable caddy.
# caddy_config (string): Optional full path for caddy config file
# caddy_adapter (string): Optional adapter type if the configuration is not in caddyfile format
# caddy_extra_flags (string): Optional flags passed to caddy start
# caddy_logfile (string): Set to "/var/log/caddy.log" by default.
# Defines where the process log file is written, this is not a web access log
. /etc/rc.subr
name=caddy
rcvar=caddy_enable
desc="Caddy 2 is a powerful, enterprise-ready, open source web server with automatic HTTPS written in Go"
load_rc_config $name
# Defaults
: ${caddy_enable:=NO}
: ${caddy_config:="/usr/local/etc/Caddyfile"}
: ${caddy_adapter:=caddyfile}
: ${caddy_extra_flags:=""}
: ${caddy_logfile="/var/log/caddy.log"}
command="/usr/local/bin/${name}"
caddy_flags="--config ${caddy_config} --adapter ${caddy_adapter}"
pidfile="/var/run/${name}.pid"
required_files="${caddy_config} ${command}"
# Extra Commands
extra_commands="validate reload"
start_cmd="${command} start ${caddy_flags} ${caddy_extra_flags} --pidfile ${pidfile} >> ${caddy_logfile} 2>&1"
validate_cmd="${command} validate ${caddy_flags}"
reload_cmd="${command} reload ${caddy_flags}"
run_rc_command "$1"
email stu.pitt@dumas.com
www.udance.com.au udance.com.au {
output file /var/log/udance.com.au.log
format console
reverse_proxy https://10.1.1.23 {
tls_insecure_skip_verify
A stripped-down, but working V1 Caddyfile:
gzip
proxy / http://10.1.1.23 {
When I try (what I think is) the V2 version of the Caddyfile (with some staging and extra logging), and try to access the site, I first see:
Clicking Advanced and proceeding, I see…
The console log…
{"level":"info","ts":1596223924.742527,"msg":"using provided configuration","config_file":"/usr/local/www/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1596223924.7474186,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
2020/08/01 03:32:04 [INFO][cache:0xc0006507e0] Started certificate maintenance routine
{"level":"info","ts":1596223924.7482967,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1596223924.7483904,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1596223924.7534752,"logger":"tls","msg":"cleaned up storage units"}
{"level":"info","ts":1596223924.7536786,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["www.udance.com.au","udance.com.au"]}
{"level":"info","ts":1596223924.7878313,"msg":"autosaved config","file":"/.config/caddy/autosave.json"}
{"level":"info","ts":1596223924.7878964,"msg":"serving initial configuration"}
Successfully started Caddy (pid=34086) - Caddy is running in the background
2020/08/01 03:32:18 http: TLS handshake error from 10.1.1.149:52847: remote error: tls: unknown certificate
2020/08/01 03:32:18 http: TLS handshake error from 10.1.1.149:52852: remote error: tls: unknown certificate
2020/08/01 03:32:21 http: TLS handshake error from 10.1.1.149:52862: remote error: tls: unknown certificate
{"level":"error","ts":1596223941.691412,"logger":"http.log.error.log0","msg":"dial tcp 10.1.1.23:443: connect: connection refused","request":{"method":"GET","uri":"/","proto":"HTTP/2.0","remote_addr":"10.1.1.149:52864","host":"www.udance.com.au","headers":{"Cache-Control":["max-age=0"],"Upgrade-Insecure-Requests":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Site":["none"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 Edg/84.0.522.49"],"Sec-Fetch-Mode":["navigate"],"Accept-Language":["en-US,en;q=0.9"]},"tls":{"resumed":false,"version":772,"ciphersuite":4865,"proto":"h2","proto_mutual":true,"server_name":"www.udance.com.au"}},"duration":0.001372649,"status":502,"err_id":"80v91b7zx","err_trace":"reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:411)"}
{"level":"info","ts":1596223949.649602,"msg":"shutting down apps then terminating","signal":"SIGTERM"}
2020/08/01 03:32:29 [INFO][cache:0xc0006507e0] Stopped certificate maintenance routine
{"level":"info","ts":1596223949.6507356,"logger":"admin","msg":"stopped previous server"}
{"level":"info","ts":1596223949.6508896,"msg":"shutdown done","signal":"SIGTERM"}
The access log…
1.5962239416915581e+09 error http.log.access.log0 handled request {"request": {"method": "GET", "uri": "/", "proto": "HTTP/2.0", "remote_addr": "10.1.1.149:52864", "host": "www.udance.com.au", "headers": {"Cache-Control": ["max-age=0"], "Upgrade-Insecure-Requests": ["1"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"], "Sec-Fetch-Site": ["none"], "Sec-Fetch-User": ["?1"], "Sec-Fetch-Dest": ["document"], "Accept-Encoding": ["gzip, deflate, br"], "User-Agent": ["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36 Edg/84.0.522.49"], "Sec-Fetch-Mode": ["navigate"], "Accept-Language": ["en-US,en;q=0.9"]}, "tls": {"resumed": false, "version": 772, "ciphersuite": 4865, "proto": "h2", "proto_mutual": true, "server_name": "www.udance.com.au"}}, "common_log": "10.1.1.149 - - [01/Aug/2020:03:32:21 +0800] \"GET / HTTP/2.0\" 502 0", "duration": 0.001372649, "size": 0, "status": 502, "resp_headers": {"Server": ["Caddy"]}}
I’ve tried twiddling as many knobs as I can, but have got nowhere. There’s something in the logs, I’ve tried searching the forum using various keywords from the logs, but I’m completely bamboozled. Looking at the logs reminds of what Cypher said to Neo in one of my favourite movies ‘There’s way too much information to decode the Matrix’.
N/A
