1. Output of caddy version
-bash: caddy: command not found
I installed the Caddy package from apt and am now trying to use a custom build with the Cloudflare plugin installed. It’s a small Linode server running Debian 11.
sudo systemctl start caddy
I’m not sure where to find this, but I don’t think that it is relevant.
I haven’t got this far yet.
Because I need certificates for domains that point to local IPs, I’ve been trying to build Caddy with the Cloudflare plugin installed, since I use Cloudflare for my DNS. After building it successfully with xcaddy
, I tried to follow the instructions for " Package support files for custom builds for Debian/Ubuntu/Raspbian" because I’d like to keep my configuration as close to “vanilla” Caddy as possible, but now whenever I try to execute a Caddy command, it reports that the command is not found.
I tried undoing all the changes made by the instructions (removing the dpkg diversion and the update-alternatives
group) and then uninstalling and reinstalling Caddy, as well as rebuilding the modified binary and ensuring it had execution permissions before copying it to /usr/bin
as part of the steps.
Package support files for custom builds for Debian/Ubuntu/Raspbian - Build from Source - Caddy
