v2.4.5 h1:P1mRs6V2cMcagSPn+NWpD+OEYUYLIf6ecOa48cFGeUg=
in a docker image
ubuntu based docker image
caddy --config /etc/caddy/Caddyfile
S6 running the command above
order replace after encode
redir /subpath /subpath/
route /subpath/* {
uri strip_prefix /subpath
replace {
http://example/(subpath/)? {http.request.host}/subpath/
reverse_proxy {
to 127.0.0.1:8081
header_down Location (https?://)([^/]+)/(subpath/)? $2$3/subpath/
header_down Location ^/(subpath/)? /subpath/
header_up Access-Control-Allow-Origin '*'
attempting to use {http.request.host} as part of the replacement in replace_response doesn’t use the placeholder. Instead it uses the literal string {http.request.host}
console error shows http
just as above
n/a
