That’s working with access (http only currently), I’m wondering if it because I didn’t have a zerossl account until now. Would that cause issues?
I have to admit I haven’t read all 21 posts in this thread. What is the exact problem now? Is it this?
If that’s the case, then it sounds like curl isn’t even trying to connect to Caddy. You can enable debug logs and if it is reaching Caddy, then you’ll see an error. If not, then something isn’t configured right with your network or DNS.
Before we continue troubleshooting, we’ll need evidence (from your Caddy logs) that the connection attempt you’re screenshotting is in fact with Caddy and not something else.
Port config issue!! Fixed it! External port XXXX to Internal port XXXX, I had internal port of YYYY instead. My bad, it had been awhile since I had the port forwarding all entered and configured from the past setup I had done. Thank you Matt and Francis!
