Caddy is runned via a systemd service. Caddy was installed via the official repo ( https://apt.fury.io/caddy/ )
Debian 11 Bullseye
caddy service restart
# General Options
admin off
# TLS Options
email mail@gmail.com
@tls
tls{
protocols tls1.3
# Config reverse Proxy
hyperviseur.domaine.fr {
reverse_proxy 192.168.1.50:80
@tls
bitwarden.domaine.fr {
reverse_proxy 192.168.1.50:8080
@tls
zabbix.domaine.fr {
reverse_proxy 192.168.1.120:80
@tls
fog.domaine.fr {
reverse_proxy 192.168.1.140:80
@tls
wiki.domaine.fr {
reverse_proxy 192.168.1.170:80
@tls
I want to not repeat the tls directive, i tried with a named matcher like this:
@tls1.3 {
protocols tls1.3
service caddy status
● caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2021-01-01 12:58:23 CET; 31s ago
Process: 21793 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1/FAILURE)
Main PID: 21793 (code=exited, status=1/FAILURE)
janv. 01 12:58:23 debian-reverse caddy[21793]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
janv. 01 12:58:23 debian-reverse caddy[21793]: HOME=/var/lib/caddy
janv. 01 12:58:23 debian-reverse caddy[21793]: LOGNAME=caddy
janv. 01 12:58:23 debian-reverse caddy[21793]: USER=caddy
janv. 01 12:58:23 debian-reverse caddy[21793]: INVOCATION_ID=8b05406d37d64793b5503e88d015ab1a
janv. 01 12:58:23 debian-reverse caddy[21793]: JOURNAL_STREAM=8:279619
janv. 01 12:58:23 debian-reverse caddy[21793]: {"level":"info","ts":1609502303.9332616,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
janv. 01 12:58:23 debian-reverse caddy[21793]: run: adapting config using caddyfile: cannot define a matcher outside of a site block: '@tls'
janv. 01 12:58:23 debian-reverse systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
janv. 01 12:58:23 debian-reverse systemd[1]: caddy.service: Failed with result 'exit-code'.
I’ve added the tls directive in each website block
I looked here maybe i’m wrong
