This is from a VPS from DigitalOcean:
[root@v2 tmp]# curl -v -I "https://caddyserver.com/%"
* Trying 165.227.20.207...
* TCP_NODELAY set
* Connected to caddyserver.com (165.227.20.207) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
* TLSv1.3 (IN), TLS handshake, [no content] (0):
* TLSv1.3 (OUT), TLS handshake, [no content] (0):
* subject: CN=caddyserver.com
* start date: Nov 4 07:01:19 2022 GMT
* expire date: Feb 2 07:01:18 2023 GMT
* subjectAltName: host "caddyserver.com" matched cert's "caddyserver.com"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* TLSv1.3 (OUT), TLS app data, [no content] (0):
* Using Stream ID: 1 (easy handle 0x55a0f6c714a0)
> HEAD /% HTTP/2
> Host: caddyserver.com
> User-Agent: curl/7.61.1
* TLSv1.3 (IN), TLS app data, [no content] (0):
* HTTP/2 stream 0 was not closed cleanly: PROTOCOL_ERROR (err 1)
* stopped the pause stream!
* Connection #0 to host caddyserver.com left intact
curl: (92) HTTP/2 stream 0 was not closed cleanly: PROTOCOL_ERROR (err 1)
And this one from my local development laptop:
cristi@MacBook-Pro ~ % curl -v -I "https://caddyserver.com/%"
* Trying 165.227.20.207:443...
* ALPN: offers h2
* ALPN: offers http/1.1
* CAfile: /etc/ssl/cert.pem
* CApath: none
* (304) (IN), TLS handshake, Server hello (2):
* (304) (IN), TLS handshake, Unknown (8):
* (304) (IN), TLS handshake, Certificate (11):
* (304) (IN), TLS handshake, CERT verify (15):
* (304) (IN), TLS handshake, Finished (20):
* (304) (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / AEAD-AES128-GCM-SHA256
* ALPN: server accepted h2
* h2h3 [:method: HEAD]
* h2h3 [:path: /%]
* h2h3 [:scheme: https]
* h2h3 [:authority: caddyserver.com]
* h2h3 [user-agent: curl/7.84.0]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x7fa4a680ec00)
> HEAD /% HTTP/2
> accept: */*
