Using experimental QUIC
version of caddy 2.4.6 so simulate an old cve for my thesis. But i cant setup the experimental http3 support which should be possible in that version. How to make a config file which i can use to connect to a client also in my local network to connect the server which should run with http3.
adapting config using caddyfile: /etc/caddy/Caddyfile:2: unrecognized global option: experimental_http3
v2.4.6 installed via github releases
installed with github releases and run on a ubuntu 18 VM
a. System environment: VM ubuntu 18
This is my config file:
experimental_http3
192.168.0.102 {
tls ./server.crt ./server.key
root * /var/www/html
### d. My complete Caddy config:
    experimental_http3
192.168.0.102 {
LEAVE DOMAIN NAMES INTACT.
If using the Caddyfile:
  - Please use `caddy fmt` to make your config more legible.
  - Review https://caddyserver.com/docs/caddyfile/concepts#structure
### 5. Links to relevant resources:
This did not work beacuase my config file does not accept this https://caddy.community/t/caddyfile-configuration-for-caddy-2-4-6-to-enable-quic-protocol/22097
<!-- Optional, but can help get us on the same page quickly. -->
Sorry for the delay, was taking some time off from the forums.
I think the config was:
	servers {
		protocols {
			experimental_http3
Thank you so much for the response, in the mean time if had already fixed it. Sadly my client won’t communicate with version 2.4.6 so I tried version 2.5.0 which can establish the connection. Do you think this is also sufficient enough to simulate this CVE
https://nvd.nist.gov/vuln/detail/CVE-2022-30591
According to nist versions of up to quic-go 27 should be vulnerable but somehow I can’t see the affects of the MTU discovery issue when using caddy version 2.5.0, is there any documentation wether this was fixed before caddy release 2.5.0 ?
We didn’t keep track of that, we just updated the quic-go dependency as necessary. You’d have to dig into quic-go to see which versions applied.
