v2.2.1
its part of the caddy image, it starts on its own
Caddy 2.2.1 on Ubuntu 18.04 official image
paste full file contents here
[redacted]
root * /var/www/html
output file /var/log/caddy.log
encode zstd gzip
If it update the caddyfile in /etc/caddy and do systemctl reload caddy it clearly restarts caddy but no content is served at all via a browser
If I kill caddy via systemctl, then run it manually from inside the /etc/caddy with caddy start everything is fine; clearly systemd is not set up correctly to launch caddy with the caddyfile
No output
Running it manually works great, running with syscontrl does nothing. I looked for a caddy.service file but I don’t see one. Where should it be, or why is something called an official image not set up?
