SO, I have updated Caddy just today (when this post was made) and when i restarted the service, it gave an error, so i checked journalctl -xe
, and it showed this error
-- Unit Caddy.service has finished starting up.
-- The start-up result is done.
Dec 31 22:00:44 merith-tk caddy[7887]: /opt/vhosts/merith.conf:2 - Error during parsing: Unknown directive 'www.merith.tk,'
Dec 31 22:00:44 merith-tk systemd[1]: Caddy.service: Main process exited, code=exited, status=1/FAILURE
Dec 31 22:00:44 merith-tk systemd[1]: Caddy.service: Unit entered failed state.
Dec 31 22:00:44 merith-tk systemd[1]: Caddy.service: Failed with result 'exit-code'.
Below is the caddy file for this page,
#WWW Config
www.merith.tk, merith.tk {
root /opt/www/html
index index.html
log /var/log/caddy/merith-tk.log
errors /var/log/caddy/errors.log
#Clones from a specific repo
git {
repo gitea@192.168.0.121:merith/merith-tk_homepage.git
branch master
key /opt/git
path /opt/www/html
interval 120
this is the command i used to update caddy
curl https://getcaddy.com | bash -s personal hook.service,http.filemanager,http.forwardproxy,http.git,http.proxyprotocol
