What would be the syntax to “insert” a prefix to a path?
Was wanting to do something like this:
uri_substring:
- find: *
replace: /path/im/inserting/{path}
(yaml config)
However, the * does not work.
Basically, for all requests to the proxy I want to hit the upstream with the same path but with /path/im/inserting inserted in the front of the path.
Don’t use uri_substring
, use uri
instead.
The value would be /prefix{uri}
Using {uri}
makes sure the query part is also preserved, otherwise only rewriting with {path}
would drop the query.
Thank you! Heh - we thought we had it working and did not see your answer right away. You can guess why we came back to look? Yep - weirdness with the query string.
@Ray_Johnson I realized reading this again that you’re using YAML, so I don’t think {uri}
is correct, because that’s a Caddyfile placeholder shortcut:
So you likely instead want {http.request.uri}
system
(system)
closed
July 9, 2021, 6:36pm
#5
