UPSTREAMS env var not being processed
Hi, I’m trying to pass UPSTREAMS env var to Caddyfile as documented here. But it doesn’t seem to work. It works fine when I hard code upstreams in reverse_proxy.
v2.8.4
I’m using caddy inside docker container.
Here is my dockerfile
FROM caddy:2.8.4-builder AS builder
RUN xcaddy build \
    --with github.com/mholt/caddy-ratelimit
FROM caddy:2.8.4
and my docker-compose
  # https://caddyserver.com/docs/running#setup
    build:
      context: .
      dockerfile: Dockerfile.caddy
      - DOMAIN=${DOMAIN:-http://localhost:80}
      - CERT_EMAIL=$CERT_EMAIL
      - UPSTREAMS="node-server-1:5000 node-server-2:5000"
      - ./caddy_data:/data
      - ./caddy_config:/config
      - 443:443
	email {$CERT_EMAIL}
	# https://github.com/mholt/caddy-ratelimit?tab=readme-ov-file#caddyfile-config
	order rate_limit before basicauth
		level ERROR
{$DOMAIN} {
	rate_limit {
		zone myzone {
			key {remote_ip}
			events 20
			window 1m
		reverse_proxy {
			# THIS WORKS
			# to node-server-1:5000 node-server-2:5000
			# THIS DOESN'T WORK
         		to {$UPSTREAMS}
			# https://caddyserver.com/docs/caddyfile/directives/reverse_proxy#load-balancing
			lb_policy round_robin
			lb_try_duration 1s
	# https://caddyserver.com/docs/caddyfile/directives/handle_errors#examples
	handle_errors 429 {
		respond "You're being rate limited. Please try again in 1 minute."
What do you mean by this? Show evidence. Show the symptoms. Show your logs. Don’t skip parts of the help topic template.
Please never say “doesn’t work” when you’re asking for help, it’s meaningless. Be specific.
I think the problem is the quotes. I think this causes the quotes to be kept in the env var, so you end up with to "node-server-1:5000 node-server-2:5000" which is one token, not two.
You’re right. Removing the quotes solved the problem
      - UPSTREAMS=node-server-1:5000 node-server-2:5000
