Current:
v2.0.0-beta.15 h1:Td1esMk7bebftnoBuT3gOqUGxew5HqdIKw3s36S8tNw=
Want to update to:
- Ubuntu: 20.04.1
- Go: 1.15.7
- xcaddy: 0.1.7
sudo systemctl daemon-reload
sudo systemctl enable caddy
sudo systemctl start caddy
Description=Caddy Web Server
After=network.target
ExecStart=/usr/bin/caddy run --config /etc/caddy/caddy.json --resume --environ
ExecReload=/usr/bin/caddy reload --config /etc/caddy/caddy.json
"apps": {
"tls": {
"automation": {
"policies": [{
"hosts": ["*.tryhexadecimal.com"],
"management": {
"module": "acme",
"email": "letsencrypt@tryhexadecimal.com",
"challenges": {
"dns": {
"provider": "cloudflare",
"api_token": ""
"management": {
"module": "acme",
"on_demand": true
"on_demand": {
"ask": "https://dashboard.tryhexadecimal.com/webhooks/caddy"
"http": {
"servers": {
"srv0": {
"listen": [
":443"
"routes": [
"match": [
"host": [
"*.tryhexadecimal.com",
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"encodings": {
"gzip": {}
"handler": "encode"
"handler": "reverse_proxy",
"headers": {
"request": {
"set": {
"Host": [
"{http.request.host}"
"X-Forwarded-For": [
"{http.request.remote.host}"
"X-Forwarded-Port": [
"{server_port}"
"X-Forwarded-Proto": [
"{http.request.scheme}"
"X-Real-Ip": [
"upstreams": [
"dial": "0.0.0.0:3000"
"terminal": true
I’m trying to upgrade Caddy from 2.0.0.beta15
to 2.3.0
. I just want to make sure I didn’t miss anything:
tls > automation > policies:
management
was renamed toissuers
- tls > automation > policies:
hosts
was renamed tosubjects
issuers
is now an array of objects, instead of an object - tls > automation > policies:
on_demand
field is not part of theissuers
anymore -
tls > automation > policies > issuers > acme > challenges > dns > provider:
provider
is now an object, instead of a string
Based on the above, here’s the updated config file. Am I missing something?
"apps": {
"tls": {
"automation": {
"policies": [{
"subjects": ["*.tryhexadecimal.com"],
"issuers": [{
"module": "acme",
"challenges": {
"dns": {
"provider": {
"name": "cloudflare",
"api_token": "API KEY"
"issuers": [{
"module": "acme",
"on_demand": true
"on_demand": {
"ask": "WEBHOOK URL"
"http": {
"servers": {
"srv0": {
"listen": [
":443"
"routes": [
"match": [
"host": [
"handle": [
"routes": [
"handle": [
"encodings": {
"gzip": {}
"handler": "encode"
"headers": {
"request": {
"set": {
"Host": [
"{server_port}"
"X-Real-Ip": [
"upstreams": [
"terminal": true
I get the “failed to install root certificate” message. Based on the previous threads, this shouldn’t be a big deal?
{"level":"error","ts":1611840704.7908254,"logger":"pki.ca.local","msg":"failed to install root certificate","error":"failed to execute sudo: exit status 1","certificate_file":"storage:pki/authorities/local/root.crt"}
