Ubuntu 20, using systemd
/usr/bin/caddy run -config=/etc/caddy/Caddyfile
not relevant. Getting same results in cli as in systemd
example.com {
reverse_proxy / localhost:8002 {
output stdout
level debug
cache {
match_path /mypath
default_max_age 10m
path /tmp/caddy-cache
I get unrecognized directive: cache
. Am trying to cache like I did in Caddy1.
Tried it on caddy 1 but since that is no longer supported I am moving to caddy 2. Also tried searching through the code and docs for caching layer but no luck.
