Unknown field split_path using adjacent Caddyfile
I just updated to Caddy 2 Stable from RC3. When I try caddy reload, it throws the following error:
2020/05/07 08:02:29.237 INFO    using adjacent Caddyfile
reload: sending configuration to instance: caddy responded with error: HTTP 400: {"error":"loading config: loading new config: loading http app module: provision http: server srv0: setting up route handlers: route 0: loading handler modules: position 0: loading module 'subroute': provision http.handlers.subroute: setting up subroutes: route 4: loading matcher modules: module name 'file': decoding module config: http.matchers.file: json: unknown field \"split_path\""}
The following Code on Caddy file was working fine on RC3. But, it is showing above error after updating to v2 stable release.
example1.com, www.example1.com, cdn.example1.com {
tls /etc/letsencrypt/live/example1.com/fullchain.pem /etc/letsencrypt/live/example1.com/privkey.pem
root * /var/www/html/example2
php_fastcgi unix//var/opt/remi/php74/run/php-fpm/www.sock
header Strict-Transport-Security max-age=7884000
@static {
file
path *.ico *.css *.js *.gif *.jpg *.jpeg *.png *.svg *.woff *.woff2
header @static Cache-Control max-age=7884000
output file /var/log/caddy/example1.log
format console
example2.com, www.example2.com, cdn.example2.com {
tls /etc/letsencrypt/live/example2.com/fullchain.pem /etc/letsencrypt/live/example2.com/privkey.pem
@static {
file
output file /var/log/caddy/example2.log
format console
Please help me with this.
Can you please mark your error and your configs as code, so indentation is preserved and it’s easier to read?
As for split_path, I don’t see it mentioned anywhere in your config…
To elaborate a bit on @piranha’s advice, you can do that by surrounding your config in triple backticks (```).
You can alternately just paste it all, select it, and then hit the “Preformatted text” button in the post editor:
Screen Shot 2020-05-07 at 7.04.51 pm
This will make it much easier to help you.
oh okay but I am in need of solution please.
Man, you won’t get much help without any real effort from your side. It’s just tiring to read plain text with no indentation, plus I have feeling that you didn’t post whole config.
I think you need to read this.
Okay done that! n Yes that’s the whole config man.
It is really like that, with no identation? I think if you had it like that it would be easier to edit and read:
  @static {
    file
    format console
  @static {
    file
    format console
I don’t see anything about split_path here, maybe someone more experienced can comment on that.
@piranha do you think that’s the bug on Caddy itself? @Whitestrake any clue?
Okay I got the answer on Github. What I need to do after update is:
caddy stop
caddy start
& then
caddy reload
Works.
i’m still trying to figure out why you’re using custom certificates while caddy is handling that already for you
  • format console is default you can delete this line if you want.
  • encode zstd gzip will compress better.
For reference, it was answered here:
@tweeniev2 I removed format console and now using encode zstd gzip.
I am using custom certificate because Dovecot and Postfix are also using those certificates. So, to make same certificate work for both email and website, I am using custom certificate. In that case, I have not removed certbot.
On the other hand, that cdn . example . com is working on Cloudfront with that certificate. And then, I am using Cloudfront directly on my apex domain.
I may try something else out soon after I get more and more familiar with Caddy. Right now I am a starter!
i am doing same. my email server got different certificate and website got different.
