– Logs begin at Fri 2021-09-17 13:37:49 UTC, end at Tue 2021-10-05 12:20:36 UTC. –
Sep 17 13:46:42 ip-172-31-4-75 systemd[1]: Starting Caddy…
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: caddy.HomeDir=/var/lib/caddy
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: caddy.Version=v2.4.5 h1:P1mRs6V2cMcagSPn+NWpD+OEYUYLIf6ecOa48cFGeUg=
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: runtime.GOOS=linux
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: runtime.GOARCH=amd64
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: runtime.Compiler=gc
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: runtime.NumCPU=1
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: runtime.GOMAXPROCS=1
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: runtime.Version=go1.17
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: os.Getwd=/
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: LANG=C.UTF-8
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: NOTIFY_SOCKET=/run/systemd/notify
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: HOME=/var/lib/caddy
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: LOGNAME=caddy
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: USER=caddy
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: INVOCATION_ID=a191988ab43d4630a843b890ab2217af
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: JOURNAL_STREAM=9:35373
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886402.6873615,“msg”:“resuming from last configuration”,“autosave_file”:"/var/lib/caddy/.config/caddy/autosave.json"}
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886402.6933904,“logger”:“admin”,“msg”:“admin endpoint started”,“address”:“tcp/localhost:2019”,“enforce_origin”:false,“origins”:[“localhost:2019”,"[::1]:2019",“127.0.0.1:2019”]}
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886402.6943903,“logger”:“http”,“msg”:“server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server”,“server_name”:“srv0”,“http_port”:80}
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886402.6960578,“msg”:“autosaved config (load with --resume flag)”,“file”:"/var/lib/caddy/.config/caddy/autosave.json"}
Sep 17 13:46:42 ip-172-31-4-75 systemd[1]: Started Caddy.
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886402.699424,“msg”:“serving initial configuration”}
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886402.6997726,“logger”:“tls.cache.maintenance”,“msg”:“started background certificate maintenance”,“cache”:“0xc000529d50”}
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886402.699928,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 17 13:46:42 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886402.700063,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 17 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886406.2138107,“logger”:“admin.api”,“msg”:“received request”,“method”:“POST”,“host”:“localhost:2019”,“uri”:"/load",“remote_addr”:“127.0.0.1:41804”,“headers”:{“Accept”:["/"],“Content-Length”:[“2680”],“Content-Type”:[“application/json”],“Expect”:[“100-continue”],“User-Agent”:[“curl/7.68.0”]}}
Sep 17 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886406.2149599,“logger”:“admin”,“msg”:“admin endpoint started”,“address”:“tcp/localhost:2019”,“enforce_origin”:false,“origins”:[“127.0.0.1:2019”,“localhost:2019”,"[::1]:2019"]}
Sep 17 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886406.2152064,“logger”:“http”,“msg”:“server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS”,“server_name”:“srv0”,“https_port”:443}
Sep 17 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886406.2152188,“logger”:“http”,“msg”:“enabling automatic HTTP->HTTPS redirects”,“server_name”:“srv0”}
Sep 17 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886406.2166758,“logger”:“tls.cache.maintenance”,“msg”:“started background certificate maintenance”,“cache”:“0xc0000da930”}
Sep 17 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886406.2178972,“logger”:“tls.cache.maintenance”,“msg”:“stopped background certificate maintenance”,“cache”:“0xc000529d50”}
Sep 17 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886406.218044,“msg”:“autosaved config (load with --resume flag)”,“file”:"/var/lib/caddy/.config/caddy/autosave.json"}
Sep 17 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886406.218418,“logger”:“admin.api”,“msg”:“load complete”}
Sep 17 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886406.2205467,“logger”:“admin”,“msg”:“stopped previous server”,“address”:“tcp/localhost:2019”}
Sep 17 13:49:12 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886552.113539,“logger”:“admin.api”,“msg”:“received request”,“method”:“POST”,“host”:“localhost:2019”,“uri”:"/load",“remote_addr”:“127.0.0.1:41808”,“headers”:{“Accept”:["/"],“Content-Length”:[“2680”],“Content-Type”:[“application/json”],“Expect”:[“100-continue”],“User-Agent”:[“curl/7.68.0”]}}
Sep 17 13:49:12 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886552.1153305,“logger”:“admin.api”,“msg”:“config is unchanged”}
Sep 17 13:49:12 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886552.1158943,“logger”:“admin.api”,“msg”:“load complete”}
Sep 17 13:49:27 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886567.4245775,“logger”:“admin.api”,“msg”:“received request”,“method”:“POST”,“host”:“localhost:2019”,“uri”:"/load",“remote_addr”:“127.0.0.1:41810”,“headers”:{“Accept”:["/"],“Content-Length”:[“2680”],“Content-Type”:[“application/json”],“Expect”:[“100-continue”],“User-Agent”:[“curl/7.68.0”]}}
Sep 17 13:49:27 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886567.426374,“logger”:“admin.api”,“msg”:“config is unchanged”}
Sep 17 13:49:27 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886567.4269352,“logger”:“admin.api”,“msg”:“load complete”}
Sep 17 13:50:06 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631886606.1793516,“logger”:“admin.api”,“msg”:“received request”,“method”:“GET”,“host”:“localhost:2019”,“uri”:"/config/",“remote_addr”:“127.0.0.1:41812”,“headers”:{“Accept”:["/"],“User-Agent”:[“curl/7.68.0”]}}
Sep 18 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631972806.2938635,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 18 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1631972806.2958264,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 19 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632059206.2166824,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 19 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632059206.2173967,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 20 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632145606.2166595,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 20 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632145606.216787,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 21 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632232006.2166758,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 21 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632232006.217369,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 22 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632318406.3000956,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 22 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632318406.300157,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 23 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632404806.2976544,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 23 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632404806.2977145,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 24 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632491206.2976825,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 24 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632491206.2977407,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 25 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632577606.2166533,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 25 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632577606.2167127,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 26 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632664006.216655,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 26 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632664006.216714,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 27 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632750406.299684,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 27 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632750406.2997434,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 28 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632836806.2166605,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 28 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632836806.2167256,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 29 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632923206.2774034,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 29 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1632923206.2774634,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Sep 30 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633009606.216655,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Sep 30 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633009606.2167463,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Oct 01 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633096006.2166736,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Oct 01 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633096006.216755,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Oct 02 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633182406.2672007,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Oct 02 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633182406.2672613,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Oct 03 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633268806.2166529,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Oct 03 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633268806.2167265,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Oct 04 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633355206.2166567,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Oct 04 13:46:46 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633355206.2173386,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Oct 05 04:43:29 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409009.9394188,“logger”:“admin.api”,“msg”:“received request”,“method”:“POST”,“host”:“localhost:2019”,“uri”:"/load",“remote_addr”:“127.0.0.1:47528”,“headers”:{“Accept”:["/"],“Content-Length”:[“2680”],“Content-Type”:[“application/json”],“Expect”:[“100-continue”],“User-Agent”:[“curl/7.68.0”]}}
Oct 05 04:43:29 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409009.9499884,“logger”:“admin.api”,“msg”:“config is unchanged”}
Oct 05 04:43:29 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409009.9504907,“logger”:“admin.api”,“msg”:“load complete”}
Oct 05 04:43:38 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409018.1619382,“logger”:“admin.api”,“msg”:“received request”,“method”:“GET”,“host”:“localhost:2019”,“uri”:"/config",“remote_addr”:“127.0.0.1:47530”,“headers”:{“Accept”:["/"],“User-Agent”:[“curl/7.68.0”]}}
Oct 05 04:43:40 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409020.496045,“logger”:“admin.api”,“msg”:“received request”,“method”:“GET”,“host”:“localhost:2019”,“uri”:"/config/",“remote_addr”:“127.0.0.1:47532”,“headers”:{“Accept”:["/"],“User-Agent”:[“curl/7.68.0”]}}
Oct 05 04:45:30 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409130.115962,“logger”:“admin.api”,“msg”:“received request”,“method”:“POST”,“host”:“localhost:2019”,“uri”:"/load",“remote_addr”:“127.0.0.1:47540”,“headers”:{“Accept”:["/"],“Content-Length”:[“2679”],“Content-Type”:[“application/json”],“Expect”:[“100-continue”],“User-Agent”:[“curl/7.68.0”]}}
Oct 05 04:45:30 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409130.1374352,“logger”:“admin”,“msg”:“admin endpoint started”,“address”:“tcp/localhost:2019”,“enforce_origin”:false,“origins”:[“localhost:2019”,"[::1]:2019",“127.0.0.1:2019”]}
Oct 05 04:45:30 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409130.144233,“logger”:“http”,“msg”:“server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server”,“server_name”:“srv0”,“http_port”:80}
Oct 05 04:45:30 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409130.1528978,“logger”:“tls.cache.maintenance”,“msg”:“started background certificate maintenance”,“cache”:“0xc0000ffdc0”}
Oct 05 04:45:30 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409130.1531742,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/var/lib/caddy/.local/share/caddy”}
Oct 05 04:45:30 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409130.1533198,“logger”:“tls”,“msg”:“finished cleaning storage units”}
Oct 05 04:45:30 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409130.158921,“logger”:“tls.cache.maintenance”,“msg”:“stopped background certificate maintenance”,“cache”:“0xc0000da930”}
Oct 05 04:45:30 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409130.1624563,“msg”:“autosaved config (load with --resume flag)”,“file”:"/var/lib/caddy/.config/caddy/autosave.json"}
Oct 05 04:45:30 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409130.163101,“logger”:“admin.api”,“msg”:“load complete”}
Oct 05 04:45:30 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409130.1738257,“logger”:“admin”,“msg”:“stopped previous server”,“address”:“tcp/localhost:2019”}
Oct 05 04:45:32 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633409132.2545674,“logger”:“admin.api”,“msg”:“received request”,“method”:“GET”,“host”:“localhost:2019”,“uri”:"/config/",“remote_addr”:“127.0.0.1:47542”,“headers”:{“Accept”:["/"],“User-Agent”:[“curl/7.68.0”]}}
Oct 05 12:20:34 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633436434.812609,“logger”:“admin.api”,“msg”:“received request”,“method”:“POST”,“host”:“localhost:2019”,“uri”:"/load",“remote_addr”:“127.0.0.1:47624”,“headers”:{“Accept”:["/"],“Content-Length”:[“2680”],“Content-Type”:[“application/json”],“Expect”:[“100-continue”],“User-Agent”:[“curl/7.68.0”]}}
Oct 05 12:20:34 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633436434.8138506,“logger”:“admin”,“msg”:“admin endpoint started”,“address”:“tcp/localhost:2019”,“enforce_origin”:false,“origins”:[“localhost:2019”,"[::1]:2019",“127.0.0.1:2019”]}
Oct 05 12:20:34 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633436434.8149886,“logger”:“http”,“msg”:“server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS”,“server_name”:“srv0”,“https_port”:443}
Oct 05 12:20:34 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633436434.8151498,“logger”:“http”,“msg”:“enabling automatic HTTP->HTTPS redirects”,“server_name”:“srv0”}
Oct 05 12:20:34 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633436434.8157687,“logger”:“tls.cache.maintenance”,“msg”:“started background certificate maintenance”,“cache”:“0xc0000fe540”}
Oct 05 12:20:34 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633436434.8170793,“logger”:“tls.cache.maintenance”,“msg”:“stopped background certificate maintenance”,“cache”:“0xc0000ffdc0”}
Oct 05 12:20:34 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633436434.8173778,“msg”:“autosaved config (load with --resume flag)”,“file”:"/var/lib/caddy/.config/caddy/autosave.json"}
Oct 05 12:20:34 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633436434.8179362,“logger”:“admin.api”,“msg”:“load complete”}
Oct 05 12:20:34 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633436434.8197122,“logger”:“admin”,“msg”:“stopped previous server”,“address”:“tcp/localhost:2019”}
Oct 05 12:20:36 ip-172-31-4-75 caddy[2287]: {“level”:“info”,“ts”:1633436436.855474,“logger”:“admin.api”,“msg”:“received request”,“method”:“GET”,“host”:“localhost:2019”,“uri”:"/config/",“remote_addr”:“127.0.0.1:47626”,“headers”:{“Accept”:["/"],“User-Agent”:[“curl/7.68.0”]}}
Does Caddy works with the AWS Load Balancer??
I want to AutoScale caddy instances.
Your logs don’t show any request coming to Caddy besides the config loading and GET of localhost:2019. Can you please follow the instructions by including the DEBUG logs into the config, making requests, and checking those logs?
But What about the Autoscaling and load balancer with Caddy?
I can’t read images.
Yeah, I have to agree, posting the text is important here for so many logs. I often copy into a text editor to parse them and images make reading them unbearable.
From a helper’s perspective, posting screenshots of logs is kind of like making a purchase at a local farmers market all in pennies. Technically it can work, but it just annoys the vendor and comes across as hostile.
Please paste the text or attach a text file if you want us to help you.
Yes, mistakenly i given that.
But during giving the caddy logs i am getting errors for unlimited characters here , that’s i gave those screenshots
Those are not Caddy logs
You can link to a text file elsewhere then. Really anything but images would be preferred. Any text format.
