I am trying to find a tutorial on how to properly setup Caddy as a reverse proxy for my Docker server and pull certs from a set directory on my host. I have checked the tutorial section out:
You can pull certs from a directory with the tls directive, specifically the load subdirective. This will disable Automatic HTTPS, though, and you will need to provide more Caddyfile configuration to cover that. It’s much simpler to allow Caddy to requisition its own certificates and manage them for you.
