I’m using docker-compose. I mount the static files and the Caddyfile
I have a python script that’s responsible for getting a session id, adding them to the Caddyfile and running docker-compose up
os.system("envsubst '${sessionid} ${TENANT_DOMAIN}'< ./Caddyfile_template > Caddyfile")
version: "3.7"
image: caddy:latest
- ../dist:/srv
- caddy_data:/data
- caddy_config:/config
caddy_data:
external: true
caddy_config:
test.localhost {
@apiCalls {
path /v1/* /asset_api/* /network_topology/*
handle /* {
uri strip_prefix /dist
root * /srv
try_files {path} index.html
handle @apiCalls {
reverse_proxy @apiCalls {
header_up Host $TENANT_DOMAIN
header_up Cookie sessionid=$sessionid
to https://$TENANT_DOMAIN
tls
tls_insecure_skip_verify
read_buffer 8192
I’m trying to make my frontend routing work. If I remove the try_files
line the application works but without frontend routing, you visit the /
route and the frontend router replaces the route to /assessments (our landing page) but if you visit a specific route it throws a 404 (curl -v also shows 404). That’s why I included the try_files
line in the Caddyfile. That seemed to work at first. I launched the url test.localhost/assessments
. and instead of the 404 I see test.localhost/assessments
which is what I want to see. The network requests to the API go through the reverse proxy as expected. The problem is that my index.html has some script
tags
<script type="text/javascript" src="./js/vendor.min.js"></script>
<script type="text/javascript" src="./js/assessments.min.js"></script>
<script type="text/javascript" src="./js/assets.min.js"></script>
<script type="text/javascript" src="./js/reports.min.js"></script>
<script type="text/javascript" src="./js/scenarios.min.js"></script>
And the website starts doing this non-stop
this also occurs with the css files that I have on the website header
It started happening only when I added the try_files
line
I’ve tried different combinations of try_files. none of them solved the issue
try_files {path} {path}/ index.html
try_files {path} {path} index.html
try_files index.html
rewrite * index.html
(for anything thats not an api router or a dist file)
nothing seems to work. Any ideas why?
Thanks in advance
