1. Output of caddy version
latest
docker
arch linux
docker compose up
version: "3.9"
build: .
image: caddy
- 443:443
- caddy
- ./data:/data
- ./config:/config
- ./Caddyfile.d:/etc/caddy/Caddyfile.d
email admin@domain.xyz
acme_dns cloudflare REDACTED-
(genericheaders) {
Strict-Transport-Security "max-age=31536000; includesubdomains; preload"
(trusted_proxy_list) {
trusted_proxies 10.0.0.0/8 172.16.0.0/16 192.168.0.0/16 fc00::/7
(encoding) {
encode zstd gzip
(authelia) {
forward_auth authelia:9091 {
uri /api/verify?rd=https://auth.domain.xyz/
copy_headers Remote-User Remote-Groups Remote-Name Remote-Email
## This import needs to be included if you're relying on a trusted proxies configuration.
import trusted_proxy_list
import /etc/caddy/Caddyfile.d/*.Caddyfile
It says that the directive trusted_proxies is wrong. But I am copying that form the authelia docs:
caddy | {"level":"info","ts":1666774736.5764437,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy | Error: adapting config using caddyfile: /etc/caddy/Caddyfile:13: unrecognized directive: trusted_proxies
caddy exited with code 1
