Update: I’ve noticed some important things listing through the google, which ended up editing the existing configuration to something like:
email username@example.com
immich.example.com {
reverse_proxy 192.168.1.13:2283
*.internal.example.com {
@services host services.internal.example.com
handle @services {
- I absolutely forgot that as my domain provider is Porkbun, i actually transferred all the rights to Cloudflare a while ago so i could manage tunnels and direct accesses more easily and from one place and it was also necessary because of how cloudflare builds those tunnels.
- Having dedicated entry for sub-sub domain where i also apply wildcard is not right usage, so i ended up specifying it directly inside the wildcard entry which should handle the
by reverse-proxying it to that specified IP address.
- Ended up changing the sub-sub-domain name to services instead of homarr as homarr is basically dashboard and shortcut for all those services.
After doing this, i get NXDOMAIN (so it appears the domain is not found) and i don’t really uderstand why. I continued with debugging by using dig
command which resolved the services.internal.example.com
to 192.168.1.13 which is right. There must be something up somewhere else down the line. Do anyone spot some obvious mistakes in the configuration?
Logs from the Caddy container:
{"level":"info","ts":1732466307.3599014,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1732466307.3618736,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1732466307.3618937,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1732466307.3627098,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1732466307.3629305,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0001d7500"}
{"level":"info","ts":1732466307.3629584,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1732466307.3629723,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"debug","ts":1732466307.3630028,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["immich.example.com"]},{"subjects":["*.internal.example.com"]},{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"192.168.1.13:2283"}]}]}]}],"terminal":true},{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"192.168.1.13:80"}]}]}]}],"match":[{"host":["services.internal.example.com"]}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
{"level":"info","ts":1732466307.3634171,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1732466307.3634994,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
{"level":"debug","ts":1732466307.3636656,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
{"level":"info","ts":1732466307.3636837,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"debug","ts":1732466307.3637197,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
{"level":"info","ts":1732466307.3637311,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1732466307.363735,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["immich.example.com","*.internal.example.com"]}
{"level":"debug","ts":1732466307.364,"logger":"tls","msg":"loading managed certificate","domain":"immich.example.com","expiration":1737813534,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/data/caddy"}
{"level":"debug","ts":1732466307.364356,"logger":"tls.cache","msg":"added certificate to cache","subjects":["immich.example.com"],"expiration":1737813534,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"REDACTED","cache_size":1,"cache_capacity":10000}
{"level":"debug","ts":1732466307.3643966,"logger":"events","msg":"event","name":"cached_managed_cert","id":"f1db3e10-4ef3-428b-ba3c-ed3ed663c76f","origin":"tls","data":{"sans":["immich.example.com"]}}
{"level":"debug","ts":1732466307.3648167,"logger":"tls.cache","msg":"added certificate to cache","subjects":["*.internal.example.com"],"expiration":1740224879,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"REDACTED","cache_size":2,"cache_capacity":10000}
{"level":"debug","ts":1732466307.3648455,"logger":"events","msg":"event","name":"cached_managed_cert","id":"812719e2-4a28-4a6d-b197-72e458d58385","origin":"tls","data":{"sans":["*.internal.example.com"]}}
{"level":"info","ts":1732466307.3649552,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1732466307.3649654,"msg":"serving initial configuration"}
{"level":"info","ts":1732466307.3664086,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"ae54a2dc-338c-4779-998b-afda0d189301","try_again":1732552707.3664062,"try_again_in":86399.9999994}
{"level":"info","ts":1732466307.3664722,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"debug","ts":1732466361.0140278,"logger":"events","msg":"event","name":"tls_get_certificate","id":"afc04f07-02c9-4fa8-bfe3-cf0405899f11","origin":"tls","data":{"client_hello":{"CipherSuites":[47802,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"services.internal.example.com","SupportedCurves":[23130,4588,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[14906,772,771],"RemoteAddr":{"IP":"192.168.1.20","Port":34512,"Zone":""},"LocalAddr":{"IP":"192.168.96.2","Port":443,"Zone":""}}}}
{"level":"debug","ts":1732466361.014073,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"services.internal.example.com"}
{"level":"debug","ts":1732466361.014082,"logger":"tls.handshake","msg":"choosing certificate","identifier":"*.internal.example.com","num_choices":1}
{"level":"debug","ts":1732466361.0140955,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"*.internal.example.com","subjects":["*.internal.example.com"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"REDACTED"}
{"level":"debug","ts":1732466361.014104,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"192.168.1.20","remote_port":"34512","subjects":["*.internal.example.com"],"managed":true,"expiration":1740224879,"hash":"REDACTED"}
{"level":"debug","ts":1732466362.123472,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.1270604,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.00339328,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Cache-Control":["max-age=0"],"Sec-Ch-Ua-Mobile":["?0"],"X-Forwarded-Host":["services.internal.example.com"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Mode":["navigate"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"X-Forwarded-For":["192.168.1.20"],"Accept-Language":["en-US,en;q=0.9"],"Accept-Encoding":["gzip, deflate, br, zstd"],"X-Forwarded-Proto":["https"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Upgrade-Insecure-Requests":["1"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Cookie":["REDACTED"],"Priority":["u=0, i"],"Sec-Fetch-Site":["none"],"Sec-Fetch-User":["?1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
{"level":"debug","ts":1732466362.131779,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.1347985,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002837355,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Sec-Fetch-User":["?1"],"Accept-Encoding":["gzip, deflate, br, zstd"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Cache-Control":["max-age=0"],"X-Forwarded-For":["192.168.1.20"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Priority":["u=0, i"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Mode":["navigate"],"Cookie":["REDACTED"],"X-Forwarded-Host":["services.internal.example.com"],"Sec-Fetch-Dest":["document"],"Accept-Language":["en-US,en;q=0.9"],"Sec-Fetch-Site":["none"],"Upgrade-Insecure-Requests":["1"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
{"level":"debug","ts":1732466362.1390257,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.1418464,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002584501,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Sec-Ch-Ua-Platform":["\"Linux\""],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Sec-Fetch-Site":["none"],"X-Forwarded-Proto":["https"],"Sec-Fetch-Mode":["navigate"],"Sec-Ch-Ua-Mobile":["?0"],"Cookie":["REDACTED"],"Cache-Control":["max-age=0"],"Accept-Language":["en-US,en;q=0.9"],"Upgrade-Insecure-Requests":["1"],"X-Forwarded-Host":["services.internal.example.com"],"Priority":["u=0, i"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Accept-Encoding":["gzip, deflate, br, zstd"],"X-Forwarded-For":["192.168.1.20"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Content-Length":["0"],"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"]},"status":308}
{"level":"debug","ts":1732466362.1452703,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.1477916,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002350195,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Sec-Fetch-Dest":["document"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["services.internal.example.com"],"Upgrade-Insecure-Requests":["1"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Accept-Language":["en-US,en;q=0.9"],"Priority":["u=0, i"],"Sec-Fetch-Mode":["navigate"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Sec-Fetch-User":["?1"],"Sec-Ch-Ua-Mobile":["?0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Cache-Control":["max-age=0"],"Sec-Fetch-Site":["none"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"X-Forwarded-For":["192.168.1.20"],"Cookie":["REDACTED"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
{"level":"debug","ts":1732466362.1514044,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.1543994,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002852141,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Priority":["u=0, i"],"Upgrade-Insecure-Requests":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Ch-Ua-Mobile":["?0"],"X-Forwarded-Host":["services.internal.example.com"],"Sec-Fetch-Mode":["navigate"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"X-Forwarded-For":["192.168.1.20"],"X-Forwarded-Proto":["https"],"Cookie":["REDACTED"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Accept-Language":["en-US,en;q=0.9"],"Cache-Control":["max-age=0"],"Sec-Fetch-Site":["none"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
{"level":"debug","ts":1732466362.1576693,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.160373,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.00256368,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Upgrade-Insecure-Requests":["1"],"Sec-Ch-Ua-Mobile":["?0"],"Priority":["u=0, i"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Cache-Control":["max-age=0"],"Sec-Fetch-Dest":["document"],"Cookie":["REDACTED"],"X-Forwarded-For":["192.168.1.20"],"X-Forwarded-Host":["services.internal.example.com"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"X-Forwarded-Proto":["https"],"Accept-Language":["en-US,en;q=0.9"],"Sec-Fetch-Site":["none"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Content-Length":["0"],"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"]},"status":308}
{"level":"debug","ts":1732466362.1641977,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.1666899,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002300806,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Sec-Fetch-User":["?1"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Accept-Encoding":["gzip, deflate, br, zstd"],"Cache-Control":["max-age=0"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Site":["none"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Sec-Fetch-Mode":["navigate"],"Priority":["u=0, i"],"X-Forwarded-For":["192.168.1.20"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Accept-Language":["en-US,en;q=0.9"],"Cookie":["REDACTED"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["services.internal.example.com"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Dest":["document"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
{"level":"debug","ts":1732466362.1706831,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.1736572,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002835151,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Accept-Language":["en-US,en;q=0.9"],"Sec-Fetch-Dest":["document"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Sec-Ch-Ua-Platform":["\"Linux\""],"Cookie":["REDACTED"],"Cache-Control":["max-age=0"],"Sec-Fetch-User":["?1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"X-Forwarded-Proto":["https"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Site":["none"],"Priority":["u=0, i"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Fetch-Mode":["navigate"],"X-Forwarded-For":["192.168.1.20"],"X-Forwarded-Host":["services.internal.example.com"],"Sec-Ch-Ua-Mobile":["?0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
{"level":"debug","ts":1732466362.17698,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.1795676,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002459161,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Site":["none"],"X-Forwarded-Proto":["https"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Dest":["document"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Accept-Language":["en-US,en;q=0.9"],"X-Forwarded-Host":["services.internal.example.com"],"Sec-Fetch-Mode":["navigate"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Sec-Fetch-User":["?1"],"X-Forwarded-For":["192.168.1.20"],"Cache-Control":["max-age=0"],"Cookie":["REDACTED"],"Priority":["u=0, i"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
{"level":"debug","ts":1732466362.1833553,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.1857126,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002221694,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Cache-Control":["max-age=0"],"Sec-Fetch-Site":["none"],"Sec-Fetch-Mode":["navigate"],"X-Forwarded-For":["192.168.1.20"],"Cookie":["REDACTED"],"Sec-Fetch-User":["?1"],"Sec-Ch-Ua-Mobile":["?0"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Accept-Language":["en-US,en;q=0.9"],"Priority":["u=0, i"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Dest":["document"],"X-Forwarded-Proto":["https"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"X-Forwarded-Host":["services.internal.example.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"],"Location":["https://services.internal.example.com/"]},"status":308}
{"level":"debug","ts":1732466362.189267,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.191845,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002441187,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"X-Forwarded-For":["192.168.1.20"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Priority":["u=0, i"],"Cache-Control":["max-age=0"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Accept-Language":["en-US,en;q=0.9"],"Sec-Fetch-Dest":["document"],"Sec-Ch-Ua-Platform":["\"Linux\""],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["services.internal.example.com"],"Cookie":["REDACTED"],"Upgrade-Insecure-Requests":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Site":["none"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Content-Length":["0"],"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"]},"status":308}
{"level":"debug","ts":1732466362.1957417,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.1981552,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002259927,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Cache-Control":["max-age=0"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Upgrade-Insecure-Requests":["1"],"X-Forwarded-For":["192.168.1.20"],"X-Forwarded-Host":["services.internal.example.com"],"Cookie":["REDACTED"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Site":["none"],"X-Forwarded-Proto":["https"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Accept-Language":["en-US,en;q=0.9"],"Sec-Fetch-Dest":["document"],"Priority":["u=0, i"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"],"Location":["https://services.internal.example.com/"]},"status":308}
{"level":"debug","ts":1732466362.203452,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.207197,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.003608072,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"X-Forwarded-Host":["services.internal.example.com"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"X-Forwarded-Proto":["https"],"Sec-Fetch-Mode":["navigate"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Priority":["u=0, i"],"Accept-Encoding":["gzip, deflate, br, zstd"],"X-Forwarded-For":["192.168.1.20"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Site":["none"],"Sec-Ch-Ua-Mobile":["?0"],"Cache-Control":["max-age=0"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-User":["?1"],"Cookie":["REDACTED"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Accept-Language":["en-US,en;q=0.9"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
{"level":"debug","ts":1732466362.2121248,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.2149415,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002582814,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Cache-Control":["max-age=0"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Fetch-Site":["none"],"X-Forwarded-Host":["services.internal.example.com"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"X-Forwarded-Proto":["https"],"Priority":["u=0, i"],"Accept-Language":["en-US,en;q=0.9"],"Cookie":["REDACTED"],"Upgrade-Insecure-Requests":["1"],"X-Forwarded-For":["192.168.1.20"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Accept-Encoding":["gzip, deflate, br, zstd"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
{"level":"debug","ts":1732466362.218575,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.221346,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002623248,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Sec-Fetch-User":["?1"],"Accept-Language":["en-US,en;q=0.9"],"X-Forwarded-For":["192.168.1.20"],"X-Forwarded-Proto":["https"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Dest":["document"],"Sec-Ch-Ua-Mobile":["?0"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Cache-Control":["max-age=0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Priority":["u=0, i"],"Sec-Fetch-Site":["none"],"Upgrade-Insecure-Requests":["1"],"X-Forwarded-Host":["services.internal.example.com"],"Cookie":["REDACTED"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"],"Location":["https://services.internal.example.com/"]},"status":308}
{"level":"debug","ts":1732466362.2265975,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.229581,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002799666,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Cookie":["REDACTED"],"Accept-Language":["en-US,en;q=0.9"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Site":["none"],"X-Forwarded-Host":["services.internal.example.com"],"X-Forwarded-Proto":["https"],"Priority":["u=0, i"],"Cache-Control":["max-age=0"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Sec-Fetch-Dest":["document"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Mode":["navigate"],"Sec-Ch-Ua-Mobile":["?0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Ch-Ua-Platform":["\"Linux\""],"X-Forwarded-For":["192.168.1.20"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"],"Location":["https://services.internal.example.com/"]},"status":308}
{"level":"debug","ts":1732466362.2347925,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.2372348,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002206034,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Cache-Control":["max-age=0"],"Accept-Language":["en-US,en;q=0.9"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Fetch-Site":["none"],"X-Forwarded-For":["192.168.1.20"],"Priority":["u=0, i"],"Cookie":["REDACTED"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Fetch-User":["?1"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Sec-Fetch-Dest":["document"],"Sec-Ch-Ua-Mobile":["?0"],"X-Forwarded-Host":["services.internal.example.com"],"Upgrade-Insecure-Requests":["1"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Sec-Fetch-Mode":["navigate"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
{"level":"debug","ts":1732466362.24119,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.243659,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002315386,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Accept-Language":["en-US,en;q=0.9"],"X-Forwarded-Proto":["https"],"X-Forwarded-For":["192.168.1.20"],"Priority":["u=0, i"],"Cache-Control":["max-age=0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Ch-Ua-Mobile":["?0"],"Upgrade-Insecure-Requests":["1"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Site":["none"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Cookie":["REDACTED"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Mode":["navigate"],"X-Forwarded-Host":["services.internal.example.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
{"level":"debug","ts":1732466362.2481873,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.2507193,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.002397082,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Cookie":["REDACTED"],"Upgrade-Insecure-Requests":["1"],"Sec-Ch-Ua-Mobile":["?0"],"Priority":["u=0, i"],"Accept-Encoding":["gzip, deflate, br, zstd"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"X-Forwarded-For":["192.168.1.20"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Cache-Control":["max-age=0"],"Sec-Ch-Ua-Platform":["\"Linux\""],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["services.internal.example.com"],"Sec-Fetch-Dest":["document"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Sec-Fetch-User":["?1"],"Sec-Fetch-Mode":["navigate"],"Accept-Language":["en-US,en;q=0.9"],"Sec-Fetch-Site":["none"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"],"Location":["https://services.internal.example.com/"],"Server":["Caddy"]},"status":308}
{"level":"debug","ts":1732466362.2549567,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.1.13:80","total_upstreams":1}
{"level":"debug","ts":1732466362.2581434,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.1.13:80","duration":0.003016694,"request":{"remote_ip":"192.168.1.20","remote_port":"34512","client_ip":"192.168.1.20","proto":"HTTP/2.0","method":"GET","host":"services.internal.example.com","uri":"/","headers":{"Accept-Encoding":["gzip, deflate, br, zstd"],"Accept-Language":["en-US,en;q=0.9"],"Cookie":["REDACTED"],"Sec-Fetch-Dest":["document"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Mode":["navigate"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"131\", \"Chromium\";v=\"131\", \"Not_A Brand\";v=\"24\""],"Sec-Ch-Ua-Mobile":["?0"],"X-Forwarded-For":["192.168.1.20"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Cache-Control":["max-age=0"],"X-Forwarded-Host":["services.internal.example.com"],"Priority":["u=0, i"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"],"Sec-Fetch-Site":["none"],"Sec-Fetch-User":["?1"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"services.internal.example.com"}},"headers":{"Location":["https://services.internal.example.com/"],"Server":["Caddy"],"Date":["Sun, 24 Nov 2024 16:39:22 GMT"],"Content-Length":["0"]},"status":308}
It seems like certificate for the wildcard entry has not been even acquired. Any help?
PS: I, if course entered the environment variable for the cloudflare API token so Caddy could edit the DNS entries.
