Does anyone have any insight into how to debug 502 errors being returned when the backend being proxied is not have any errors or issues? Any help trying in troubleshooting would be appreciated.
My go-to for troubleshooting these is two-pronged:
- Enable
errors
logging in the Caddyfile on the site that is proxying to the backend - Run
curl -IL [host]
from the computer running Caddy at the backend host
The former might give some info on exactly why Caddy isn’t able to communicate with the backend, and the latter should give you an idea exactly how the backend is responding to a HTTP request from Caddy.
And that second one (using curl) is especially important for eliminating the browser cache in testing
Might also want to enable the process log (-log flag) because some errors generated by the Go standard library don’t make it into the request log – instead they get logged directly right inside the standard lib.
Thanks for the additional info. Looks like I’m getting a
07/Apr/2018:16:12:59 +0000 [ERROR 502 /] context canceled
I don’t believe the host is down at all. Any idea how I fix that?
That usually happens when a client closes the connection, not a big deal in that case.
