I have a rather complex caddy file. I want to have a sill static site - that I can then replace later with a reverse proxy to a docker container.
I added the @id tag in the config to mark the part of the config I want to change.
I can get the config no problem:
curl http://localhost:2019/id/kibana
{"@id":"kibana","handle":[{"body":"Kibana not running - run \"launch_kibana\"\n","handler":"static_response","status_code":501}],"match":[{"host":["kibana.bullseye31.dev.tilia-inc.com"]}],"terminal":true}
I now want to replace the “handle” element with a reverse proxy handler. However, I have been unable to make the right JSON to make this work. Anyone have any ideas?
This is what I’m currently trying:
JSON_STRING=$( jq -n \
--arg khost "${HOSTNAME}:5601" \
--arg chost "kibana.${HOSTNAME}" \
'{"handler":"subroute","routes":[{"handle":null}]},{"handler":"reverse_proxy","upstreams":[{"dial": $khost }]}' )
curl -s -X POST -H "Content-Type: application/json" \
-d "$JSON_STRING" \
http://localhost:2019/id/kibana/handle/0
